Help
Old Sep 15, 2009 | 08:11 PM
cumminthru's Avatar
Default Help
I need to know what this hole is in the air intake can someone tell me if I need to plug this. I checked my biddys truck and he has the same thing but neither know what it is or why it is not filled. Please help. Ok so I cannot upload the photo. Please will someone look on their 610 and tell me what I should do.
I posted a pic in another thread. Please look at the other post for the pic.
Last edited by cumminthru; Sep 15, 2009 at 08:11 PM. Reason: Automerged Doublepost
Old Sep 15, 2009 | 08:13 PM
mysterync's Avatar
I'm not seeing a picture, Are you sure your not seeing a hole for the factory air filter minder? The afe has a location to install the filter minder. Alot of "diesel performance" companys overlook the minder when installing an intake!
Old Sep 15, 2009 | 09:49 PM
tower_ofpower's Avatar
i knew a kid that used that hole as an expresse starting fluid delivery system he's lucky the intake didnt go sky high; oh well. his truck to ruin; not mine
well i found your other thread... and this kid was using the hole where the filter minder should have been not that hole... sounds like mysterync has you all straightened out
Last edited by tower_ofpower; Sep 15, 2009 at 09:49 PM. Reason: Automerged Doublepost
Old Sep 16, 2009 | 08:10 PM
cumminthru's Avatar
The hole I am tAlking about is on the intake side not the filter side. Please help I am worried.
Old Sep 16, 2009 | 09:39 PM
as mysterync stated in your other thread it was used to ground the grid heater... if your worried about a potential boost leak take a pocket screw driver down in the hole... if you hit bottom then your good to go... if you dont... then start the truck up and hold your hand over the hole... even tho you wont read any pressure on the manifold the trubo does still flow plenty of air to blow out of a hole that size
no air flow; no leak
Last edited by tower_ofpower; Sep 16, 2009 at 09:39 PM. Reason: Automerged Doublepost
