Silencer Ring
Old Sep 14, 2009 | 10:52 PM
Kentucky99's Avatar
Default Silencer Ring
wonderin about takin the silencer ring off my truck, will it hurt anything? pros? cons?
Old Sep 15, 2009 | 12:21 AM
dieseldocter16's Avatar
Wont hurt anything. The stick trucks seem to get more turbo whistle than the auto's.
Old Sep 15, 2009 | 06:30 AM
schu777's Avatar
I took mine out years ago, but in the last year or so I put it back in due to the whine was hurting my ears - seems like high pitch noises are really starting to hurt the ears. I'm very careful seeing my Dad has lost all of his high frequency hearing and don't want to be like that in 20 years.
But yes, you do get more turbo noise. I once had a guy ride with me to get lunch, he actually thought there was a police/ambulance coming!!
Michael
Old Sep 15, 2009 | 07:51 AM
dodge rodder's Avatar
if you have an cold air intake and take the ring out it will be much louder that the stock intake.
Old Sep 15, 2009 | 11:15 PM
redneckcummins85's Avatar
i noticed a huge difference in the sound ..... doesnt hurt anything though
Old Sep 16, 2009 | 10:14 AM
Wyatt Earp's Avatar
My Ring is MIA as well. Between the noise of the block and the MBRP duals this truck is loud no matter which way you slice it so as long as it doesn't bother you - ie hearing etc. do what you want as it does not effect performance in anyway.
If the truck is old enough and you are doing a tear down you can fill the interior panels with second skin or some other deadening material and that really helps keep the noise down from inside. Just a thought.
Old Sep 16, 2009 | 04:15 PM
Dan.tha.Cummins.man's Avatar
there are a ton of guys runnin w/out a silencer ring. mines out and its pretty sweet. it doesnt hurt anything at all. there is a post on here somewhere with pics and good instructions on removing it. o and it deff makes heads turn when you drive by ppl.
Old Sep 17, 2009 | 01:03 AM
Kentucky99's Avatar
thanks. i had a local mechanic tell me it would rob my low end a little, but i'd gain in top end, you didn't notice a difference?
Old Sep 17, 2009 | 09:18 AM
J-Pipes's Avatar
I was told the opposite when I was asking about mine, mechanic said if it did anything it would let the charger spool a little quicker. All I noticed is the loud wistle, which as I have gotten used to it, I don't notice nearly as much as when I first did it.
Old Sep 17, 2009 | 11:16 AM
Wyatt Earp's Avatar
Both told wrong. Cummins doesn't provide the ring, Dodge does. It will do nothing to the system at all. No gains or reductinos.
