i need help!
Old Sep 14, 2009 | 12:49 AM
bullrider96's Avatar
Default i need help!
i have a 1996 dodge 2500 and the front axle wont lock in the hubs. the transfer case is working just fine but the front wont lock in and i think it might be the vaccum module that mounts on the axle itself but not sure if anyone has any suggestions to wat it might be please help!
Old Sep 18, 2009 | 08:29 PM
tdiezel's Avatar
Im not sure what it could be. Its either the transfer case or your axles. But the transfer case is like a mini transmission for the front wheels so if its not locking it could very well be the transfer case internally not engaging the front drive line.
Old Sep 18, 2009 | 09:28 PM
biged681985's Avatar
try swapping the vacum lines on the front axle, if there backwards they wont lock in the front axle. hope ya get it figured out
Old Sep 19, 2009 | 12:17 AM
12valvetater's Avatar
check and make sure that the lines running along the crossmember havent come apart mine did that to me
Old Sep 21, 2009 | 03:08 PM
12.valve.hauler's Avatar
check your u-joints on the front and if they are bad then make sure when you pull the axle to check the splines that the sleeve slides over behind the vacuum acuator. mine were kinda screwed up from my u-joints being worn out and trying to lock in 4wd. but if they arent to bad some simple massaging with a file will fix em right up.
Old Oct 2, 2009 | 12:24 PM
RIGHT ON GUYS! YOU DID IT AGAIN THAT VACUMM MODULE IN THE FRONT AND THE LINES RUNNING ON THE CROSSMEMBER WAS THE PROBLEM THANKS FOR ALL THE HELP IT IS MUCH APPRECIATED!
Old Oct 2, 2009 | 01:38 PM
anytime fella thats what we are here for
