Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
06 duramax diesel running terrible....
Old Sep 13, 2009 | 09:33 PM
timsgsx's Avatar
Default 06 duramax diesel running terrible....
my dads got an 06 duramax 6.6l things running terrible.... he siphoned some fuel into it and turns out it had water in it. water in fuel light came on, we shut it down pulled fuel filter turns out their was almost as much water as diesel. we ended up actually taking the fuel tank off the truck and emptying it out wiped the inside out with a rag, and blew air threw the fuel line to clear the line up to the filter.all back together things skipping....has like no power barely shifts gears it is absolutely struggling. check engine light is on (water in fuel light never came back) we havent got the code read yet but any ideas wtf happened? injectors? the transmission only shifts if u let off the gas and then get back on it at high rpms...trucks got 75k on it still under warranty so will prlli end up goin to the dealer but still any ideas....thanks
Old Sep 13, 2009 | 09:38 PM
2500HeavyDuty's Avatar
sounds like its still in engine limp mode. pull the code and we can go from there
Old Sep 13, 2009 | 09:45 PM
timsgsx's Avatar
whats engine limp mode?
Old Sep 13, 2009 | 09:47 PM
it cuts down on power and limits the engine to only go past a rpm and throttle percentage.
Old Sep 13, 2009 | 09:48 PM
timsgsx's Avatar
so is it possble code just neeeds to be cleared? would it cause truck to skip a little
Old Sep 13, 2009 | 09:51 PM
if there is still something wrong with the truck the code will come back after you clear it, sometimes it does take a while for the truck to clear the code on its own so you can clear it and see what comes back
Old Sep 13, 2009 | 09:56 PM
timsgsx's Avatar
ok sounds good...limp mode can make it skip a little to?
Old Sep 13, 2009 | 10:01 PM
get that code cheked out first, it skipping is not normal
Old Sep 15, 2009 | 07:26 PM
dozerboy's Avatar
Could take a bit to get all of the air out of the lines....
Old Sep 15, 2009 | 07:50 PM
redneckbuckeye's Avatar
Ever get it figured out?
Jet A Fuel
6.7 Liter Dodge Cummins 2013+
8
Oct 21, 2015 03:30 PM
shane509
Potential Diesel Owners Forum
Sep 15, 2015 08:41 PM
Jet A Fuel
Aug 3, 2015 10:45 AM
JamesL91
Mar 15, 2015 06:11 PM
wolfnexus
Nov 4, 2014 10:04 PM
