no brake lghts need help
Old Sep 12, 2009 | 08:42 AM
cummins army's Avatar
Default no brake lghts need help
ok here it is i have no brake lights when i press the brake pedal i do have turn signals tail lights and everything else and if i use my brake controller the brake lights come on i have already changed the flasher and the plunger switch on the pedal and still no brake lights please help
Old Sep 12, 2009 | 08:53 AM
psy_6att_6ica_6's Avatar
did ya change one of them funny lookin rectangular block fuses in the under the hood fuse box. i had the same problem and thats what mine was. hope that helped.
Old Sep 12, 2009 | 09:10 AM
i havent do you rember which one it was
Old Sep 12, 2009 | 09:37 AM
its labeled under the lid where it is, i think it says brake lamps for it, if your paints wore out on your lid i can run out to mine and find it or you can try googleing a picture.
Old Nov 14, 2009 | 08:26 PM
985cumminslover's Avatar
pull your light switchoff and look at it it may be melted i had the same prooblem
Old Nov 14, 2009 | 08:29 PM
9412Valve's Avatar
I'd check your headlamp switch... I've had this problem with 2 of my dodges - they have a bad habit of melting stuff in the back or the connectors getting corroded. good luck
Hogridenfool
Nov 20, 2017 04:37 PM
weatherby
Aug 31, 2015 08:04 PM
Turbo67
Jul 25, 2015 02:26 PM
Rcracer78
Audio Equipment/Electrical
Apr 20, 2015 12:49 AM
yams
Nov 29, 2014 09:25 PM
