Diesel Dawgs Performance Visit - Diesel Dawgs Performance
03-07 Powerstroke Adrenaline
Old Sep 11, 2009 | 09:13 PM
FormerVendor
Default 03-07 Powerstroke Adrenaline
Features:
•180 RWHP Gain
•325 Ft-lbs of Torque Gain
•6 On-the-Fly Power Levels
•Max Mileage Tuning level
•Complete set of gauges – 20 + parameters
•Built-in Guardian De-fueling EGT, Boost, Transmission and More
•User defined shifting protection
•Turbo Timer
•Read and Erase DTC’s
•Failsafe Technology
•Rugged Weatherproof Enclosure
•USB Updatable
•Best Towing Performance Available
•Unparalled Throttle Response
•0-60 mph Tests
•¼ Mile Performance Test
Introducing the most powerful, most feature rich, easiest to install, and most user adjustable on-the-fly engine management system ever produced for the 6L Ford. The Adrenaline module is packed full of usable and useful features unlike other products on the market.
The heart of the Adrenaline uses proprietary software unlike any other on the market allowing us to control the entire engine via the engines control bus. Our Failsafe technology means that under NO circumstance will you ever have any truck reliability issues even if the worst case scenario presents itself!
The Adrenaline utilizes its 100% control over injector pulse width, injection timing and injection control pressure to increase efficiency and add more power. This is a unique combination that before now was only available by buying multiple products and using them together.
The Adrenaline/Pulse is much more than a power adder or fuel mileage enhancement unit. With the Pulse you have access to over 20 parameters to monitor, record, and set alarms for. You also may set de-fueling settings for most of the monitored parameters. The Adrenaline does not simply cut fuel, but matches the fueling and timing curves to maximize power output while keeping exhaust temperatures below your preset level. Simply put, it is by far the safest and smoothest engine protection system on the market.
On your Pulse monitor there is a host of features that you will love. In addition to all the gauges, you have the ability to adjust your Turbo Timer, set cold engine protection parameters, adjust fueling during shifting, test 0-60 MPH and ¼ mile times, and recall your minimum and maximum achieved parameters.
If you need more you may choose to purchase an unlock code that allows you to custom tune your Adrenaline on-the-fly via the Pulse monitor. With this feature unlocked you will be able to set maximum pulse width, maximum timing advance, maximum injection pressure, decide when to add fuel and control the pedal feel of the power plus much more!
There is no other performance product on the market that can match the features, mileage gains and power gains of the Adrenaline module.
Parameters Monitored:
EGT
Load%
RPM
IAT
Fuel Level %
TPS%
MAF
Runtime
EGR Error%
Boost
Coolant Temperature
Speed
Corrected Speed
Voltage
Gear
Transmission Temp
EGR %
Barometer
This can be ordered with or without the Pulse Monitor.
Luke
KatiTrimmell
Jun 13, 2016 12:29 PM
chrispowerstroke09
Oct 10, 2015 12:04 PM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
4doorIDIot
6.9L & 7.3L Performance
Aug 1, 2015 06:02 PM
Lsugod85
Jun 20, 2015 05:14 PM
