47re stuck in limp mode
Old Sep 11, 2009 | 02:15 AM
cudafreak's Avatar
Default 47re stuck in limp mode
1999 2500 cummins with edge attitude,5" exhaust,bd trans and billet torque convertor
One day just went into limp mode after being parked at the mall for 10 min. Operation had been normal for the 40000k on trans until then, was recently serviced a month prior. Have looked all over the net and tried several suggestions replaced the governor solenoid and pressure sensor and tps or apps and did not correct limp mode condition.
does have code for TPS low voltage input but checks out at 5V.
Anybody have any ideas
Old Sep 13, 2009 | 02:38 AM
biged681985's Avatar
have u tried adjusting the apps sensor? r u sure its in a limp mode? what is it nessasarily doing. have you made sure the connector to the tranny is plugged in for sure? have you tried to disconnect the edge from the truck and see what it does?
good luck and hope ya figure it out
Old Sep 14, 2009 | 01:53 AM
cudafreak's Avatar
I am assuming it is limp mode as when you put into drive it goes into third gear and wont shift, but is possible to down shift manually, and no overdrive or tc lockup. I have tried to adjust the apps and then replaced it with no success, checked the plugs all seem good check pcm input voltage and was good. seems like there is a million different things that it could be. I havent unhooked the Edge but will give it a try.
Woodsracer
Ford Powerstroke 2011-Up 6.7L
Jul 30, 2017 09:14 PM
Daniel Leipart
Jun 28, 2015 02:42 PM
Gm3500
May 7, 2015 11:01 AM
ClintD.
Chevy/GMC Duramax 06-07 LBZ
Mar 23, 2015 04:37 AM
syctaz
Mar 3, 2015 09:23 AM
