gauges...
Old Sep 10, 2009 | 07:54 PM
wisconsin redneck's Avatar
Default gauges...
so im getting some gauges in the mail soon (egt, fuel pressure, and boost)
so i need to make sure im drillin n tappin in the right spots..
egt i was thinkin pre turbo?? or is post turbo better?
boost and fuel press i have no idea...
thanks
bob
Old Sep 10, 2009 | 08:00 PM
mysterync's Avatar
Pre turbo is the only way to go. We always use a vac to suck out the particals we can, then start the truck without the probe installed. The hole provides less resistance than the charger, The flakes will come out the hole. Not to mention there should never be anything big enough to cause problems in the first place. I always center punch, Small bit, then a 21/64 bit
The common place for a boost gauge is under the fuel lines. You'll find two 1/4 (IIRC) ports , the one closest to the front of the truck is most commonly used!
Fuel pressure...What gauge do you have and I'll give you some ideas!
Old Sep 10, 2009 | 08:19 PM
the fuel pressure it from auto meter... thats all ik... haha ask luke... thats were i got them from... and where on the fuel lines are you talkin about exactly?? close to the injectors or closer to the fuel filter?
Old Sep 10, 2009 | 08:22 PM
mysterync's Avatar
It will be between the pump and head, under injector lines. Some folks get pressure off the fuel filter housing, thats the cleanest install that I've seen yet on a truck with factory fuel filters!
Old Sep 10, 2009 | 08:24 PM
and how do you exactly do you do that?? drill n tap?? ive herd of some guys buyin a fuel tank cap thats got a hole drilled n tapped for it?? but that doesnt sound right to me maybe im wrong
Old Sep 10, 2009 | 08:32 PM
mysterync's Avatar
The fuel filter housing has a banjo bolt that can be changed for a version with a 1/8NPT port in the top of the bolt IIRC that allows you to get fuel pressure at the entrance of the fuel filter. I'm sure some of the guys that have done it will drop in soon!
Old Sep 10, 2009 | 08:52 PM
yes drop in guys... ahhah also if nybody know where to get the "special" banjo bolt that would be helpfull!!
thanks dudes...
Old Sep 10, 2009 | 09:47 PM
jitt08's Avatar
genos will have it look at there page on hear
Old Sep 10, 2009 | 09:59 PM
i just did n they have nothin for the 95 dodge
http://www.genosgarage.com/products.asp?dept=63
ny where else i could get somethin??
Old Sep 10, 2009 | 10:51 PM
The Isspro Gauges will come with the Banjo Bolt.
