2065 rack plug
Old Sep 10, 2009 | 12:02 AM
lodal cummins's Avatar
Default 2065 rack plug
does the 2065 rack plug apply to all the 7100 pumps? what kind of gains to expect when putting 2065 plug in?
Old Sep 10, 2009 | 12:12 AM
xzaq103's Avatar
FormerVendor
Do you mean 2095 rack plug aka mack rack plug? It adds rack travel when your afc is setup to allow it. Im pretty sure its about 2mm of rack travel so maybe 30hp.
Old Sep 10, 2009 | 07:04 PM
yeah 2095! oh crap what was i thinking, 2065? thanks for your response!!!!!
Old Sep 10, 2009 | 07:51 PM
wisconsin redneck's Avatar
how much are those and who all sells them??
thanks
bob
Old Sep 11, 2009 | 02:19 AM
12valvetater's Avatar
is your truck a 5 spd if so you should not use this plug 215horse trucks with 913 pumps can use this because the more rack travel the more it retards timing you can use it in all autos and 5spds from 94-95 maybe a few in 96 remeber you cant use it in a 215hp pump
Old Sep 11, 2009 | 05:39 AM
94 12valve's Avatar
thanks
bob
like $12 pure diesel power sells them
my 215 pump has the 2095 rack plug in it
Last edited by 94 12valve; Sep 11, 2009 at 05:39 AM. Reason: Automerged Doublepost
Old Sep 11, 2009 | 07:42 AM
how do you keep it from retarding the timing?
Old Sep 11, 2009 | 08:09 AM
xzaq103's Avatar
FormerVendor
the 215s retard timing up top so when you add a rack plug to increase rack travel then you retard timing even more.
Dave when did you add yours?
Old Sep 11, 2009 | 08:38 AM
94 12valve's Avatar
mine has flat top plungers ... but for a street 215 pump you were 100% right on the no rack plug.for a competiton truck I would put a rack plug and advance the timing more.
came with the pump ... and the pump is in the mail
Old Sep 11, 2009 | 09:02 AM
tricky sum gun
