2004 6.0 boost problem
Old Sep 9, 2009 | 09:55 PM
aaronmoore's Avatar
Default 2004 6.0 boost problem
ok the dealer working on my truck said today that my nipple that my boost line hooks on to on the intake is badly clogged and needing a thorough cleaning.would this cause no boost conditions and a p2262 code.thanks in advance.
oh i meant to say the boost line on map sensor running to the nipple.thats the part thats clogged the nipple in intake
Old Sep 9, 2009 | 10:05 PM
ltr450's Avatar
it could
Old Sep 9, 2009 | 10:13 PM
aaronmoore's Avatar
so would it be a good idea to let him clean intake and all that stuff.cause weve already cleaned turbo replace egr valve and map and hose.but now he noticed the nipple was clogged and possibly the intake thanks
Old Sep 9, 2009 | 10:14 PM
ltr450's Avatar
i would clean it
Old Sep 10, 2009 | 01:00 PM
aaronmoore's Avatar
Default 2004 6.0 powerstroke help
ok guys this is the update my mechanic that cleaned the nipple on the boost sensor he cleaned that and cleaned turbo again and put it all back togethor and now it is very hard to start and will barely run and the valves are hitting hard and sounds rough any ideas.thanks in advance
he did say he sprayed brake cleaner in the intake where the nipple goes and he also blowed it out with air didnt know if that could hurt anything
Last edited by aaronmoore; Sep 10, 2009 at 01:00 PM. Reason: Automerged Doublepost
Old Sep 10, 2009 | 03:09 PM
ltr450's Avatar
hard starting would have to be a fuel issue. these 6.0 are nothing but trouble i would sell it and buy another cummins or put a 12v in it.
Old Sep 10, 2009 | 03:25 PM
aaronmoore's Avatar
also i just found out that last time he had it he welded the egr valve shut he just ordered a new but he paying for it since he welded it he said would this cause that but ive actually drove it since then.
Old Sep 10, 2009 | 03:32 PM
aaronmoore's Avatar
Default 2004 powerstroke egr valve
would a welded egr valve cause rough running issues thanks
Old Sep 10, 2009 | 03:48 PM
EngineTech's Avatar
Make sure after the EGR is replaced that the filter screen on top of the fuel pump is cleaned. This is a common problem for injector and EGR failure that Ford will never tell you about.
Old Sep 10, 2009 | 04:02 PM
aaronmoore's Avatar
ok thanks
