idle is too high
Old Sep 9, 2009 | 01:27 PM
cumminskid92's Avatar
Default idle is too high
ok so i pretty much have my pump maxed out on all the adjustments but now it idles way too high and i have the idle screw backed all the way out. i know there is another way to get to idle down i just dont know how. can someone please help me.
Old Sep 9, 2009 | 01:51 PM
2500HeavyDuty's Avatar
does this help?
https://www.dieselbombers.com/1st-ge...-pump-you.html
Old Sep 9, 2009 | 05:39 PM
RSWORDS's Avatar
You might have to grind some of teh lever away.
Read through here to see how I adjusted my idle.
Old Sep 9, 2009 | 07:22 PM
big bad diesel 416's Avatar
Site Sponsor
did you re-index the linkage?
Old Sep 9, 2009 | 07:25 PM
stillcummin's Avatar
My lever on my 4bt has a trun down that cant be ground down.the only other possibility is readjusting the throttle shaft on the splines.Rotate the lever counter clockwise 1 spline.youll probably have to turn thef uel up some more though.
john grossman
10
Jan 12, 2019 08:58 PM
robbyS
Apr 16, 2015 02:22 PM
CumminsCoalRoller24/7
Feb 21, 2015 10:44 PM
robbyS
13
Dec 20, 2014 04:25 PM
jmerriman17
Nov 21, 2014 04:38 PM
