stock tranny coolers
Old Sep 8, 2009 | 06:55 PM
lodal cummins's Avatar
Default stock tranny coolers
are the stock tranny coolers enough when doing different mods? or should you install a bigger one?
Old Sep 8, 2009 | 07:00 PM
sidekick's Avatar
the cooler you can make it the better
Old Sep 8, 2009 | 07:01 PM
Benjamin's Avatar
Bombardier
Dave Goerend told me that they, the stock coolers, are more than adequate due to the fact that the tranny from the factory was highly inadequate for the truck they put it in.
that being said, put a temp gauge in the hot line and if it gets hotter than "normal" then you should assess the situation, i would look into cleaning the coolers, changing tranny fluid to maybe a synthetic, then after that is all exhausted i would change the cooler. BTW if it is a stock tranny a new converter will help solve the heat issue as most heat is created when the converter is in NON-lockup.
Old Sep 8, 2009 | 07:03 PM
12vcummins96's Avatar
stock cooler is just fine
Old Sep 8, 2009 | 08:38 PM
thanks alot guys! the reason i asked was because of my first post about tranny smell. please read and respond if you like. trying to figure this tranny thing out.
dieselpowa
5.9L 12V Performance
Sep 12, 2015 05:28 AM
wannadrag
May 25, 2015 03:07 PM
wilki
Feb 12, 2015 09:04 AM
Ol Goat
Jan 22, 2015 02:16 AM
Ol' RED!
Dec 11, 2014 10:00 AM
