rough start
Old Sep 7, 2009 | 07:57 PM
96blackcloud's Avatar
Default rough start
after sittin for awhile maybe two days or so the truck doesnt want to start to easy? blows lots of white smoke and very rough idle until she warms up and its good to go. could it be feedin to much fuel to a cold motor to start with? plan to slide the plate back to where it was before this problem started tommo and see if that helps any ideas?
Old Sep 7, 2009 | 08:19 PM
tower_ofpower's Avatar
sliding the plate wont effect start up... at idle the arm doesnt even touch the fuel plate. diesels dont like air in the fuel. since it only does it after a day or so i'm going to say air is getting in the system somewhere. th truck really only needs to sit for X number of ours before it is considered a "cold" engine... not days. just look into the integrity of your fuel system
Old Sep 7, 2009 | 08:49 PM
wisconsin redneck's Avatar
yeh mine does the same thing... if it sits for about 2 or 3 hours... then its rough for about 30 seconds.. but starting it is fine... 2 cranks n she fires right up!!!
Old Sep 7, 2009 | 09:55 PM
bowtech's Avatar
yeah mine does to when it sits for a few days.think it air to
Old Sep 8, 2009 | 05:47 AM
alright i just changed to fuel filter but i always make sure to fill it up to the top before putin it back on.
any way to purge off air if its trapped in the system of would it be entering to system so how
Last edited by 96blackcloud; Sep 8, 2009 at 05:47 AM. Reason: Automerged Doublepost
Old Sep 8, 2009 | 09:58 AM
Usually air enters through very small holes in the rubber fuel lines (they degrade from the inside out), or at your heater/prefilter. If you havent ever replaced your fuel lines - now is the time. Its not a fun job - make sure you use diesel rated fiuel line, dont forget the lines at the tank, feed is 3/8" and return line is 5/16", and dont forget the short chunk of return line shown in the pic below (Filter canister has to come out to get to it):
Old Sep 8, 2009 | 06:44 PM
thank you very much that is some great info looks like thats what ill be doin soon then.
bdbfam
Aug 31, 2015 09:06 PM
ctjkelley
Jun 3, 2015 06:01 AM
ronstop
Feb 26, 2015 09:48 AM
kern306
Jan 5, 2015 01:07 PM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
