odometer fraud
Old Sep 7, 2009 | 03:39 PM
skyjacked84's Avatar
Default odometer fraud
is it true that if ur speedo is bouncing that it could because someones messed with the odometer?
Old Sep 7, 2009 | 04:22 PM
NadirPoint's Avatar
That is normally due to binding or wear in the cable, cable connections or gears somewhere between the drive and the cluster/gauge in a mechanical speedo linkage. Early Dodge electronic gauges used a combination of a mechanical drive gear coupled to a signal generator (VSS) to drive the 1st Gen electronic speedos. This type of speedo setup may also be subject to the same symptom for the same reason, usually a bad drive gear.
Old Sep 7, 2009 | 04:28 PM
I would bet its the cable or gear...if your talking about the 98 you have.
Old Sep 7, 2009 | 06:49 PM
is there a way 2 tell or just replace both?
Old Sep 7, 2009 | 06:53 PM
Like just about everything else, it helps to take it apart and have a look. Some things are obvious, most are not. JMO.
DirtyDiesel58
18
Sep 27, 2015 07:07 AM
gunman41mag
The Sportsmen's Lounge
Jun 15, 2015 07:20 AM
Gizmo52
12
Mar 18, 2015 07:52 PM
wyoranch
Oct 28, 2014 08:23 AM
jcottonoir
Oct 7, 2014 08:04 AM
