Changing a Fuel Filter
Old Sep 6, 2009 | 06:33 PM
Trucks Are For Girls!!!'s Avatar
Default Changing a Fuel Filter
IS there anything special I have to do before I replace my fuel filter. Or do I just unscrew it and then press on the top to prime it?
Old Sep 6, 2009 | 06:43 PM
wildbill's Avatar
Be sure to clean the water in fuel sensor.
Old Sep 6, 2009 | 06:48 PM
Diesel-N-Dust's Avatar
Unplug the wif sensor first. Sometimes it is easier to remove the inner fender liner. It is on my truck anyway.
Danny has a good write-up here:
https://www.dieselbombers.com/chevy-...placement.html
2500HeavyDuty's Avatar
unscrew the bleed screw too to make the pumping easier.
Old Sep 6, 2009 | 06:54 PM
Naw I never touch my bleed screw. I run out of fuel all the time.
Old Sep 6, 2009 | 07:00 PM
thanks guys I knew it was easy just wanted to make sure. would a dirty fuel filter make my engine light come on?
Old Sep 6, 2009 | 07:29 PM
yes
Old Sep 6, 2009 | 07:34 PM
Hey Danno. Let's go drink some Beer!
Old Sep 6, 2009 | 07:36 PM
do I need to disconnect the batteries to reset the computer since my engine light is on?
Old Sep 6, 2009 | 08:13 PM
wildbill's Avatar
Because you replaced the filter, the light should go out after 5 good key trips.
