front main seal install
Old Sep 6, 2009 | 04:34 PM
gone ropin's Avatar
Default front main seal install
Ok anybody know if theres any special way to install the front main seal on a 96 so the dang thing dosent leak ?
Old Sep 6, 2009 | 04:50 PM
jaybuller's Avatar
yeah, you have to get the seal kit. clean off your crank good with degreaser(it has to be clean and dry) put the new seal in the timing cover using the suplied install tool to get the depth right. put the instalation clear plastic sleeve over the crank and push the timing cover on the engine and over the crank snout, line the cover up and loosely put a few bolts in to hold it in place and push it on all the way, then snug it all down and torque the bolts to 18ftlbs.
thats how i did mine when i did my kdp fix and it worked fine with no leaks. also put a new timing cover gasket on it.
Old Sep 6, 2009 | 07:28 PM
stillcummin's Avatar
hold on to that plastic sleeve.I damaged every seal after ive took off my cover since the change from oem.
Old Sep 6, 2009 | 08:06 PM
jaybuller's Avatar
yes use the same seal just keep reusing the plastic sleave to reinstal the cover... good tip
shingi
Off Roading
Sep 30, 2015 11:17 AM
yfzrunner
Sep 17, 2015 05:23 AM
carid
Diesel Bombers Sponsors
Aug 11, 2015 06:24 AM
wildbill
Jan 31, 2015 11:14 AM
