Air Dog Install
Old Sep 6, 2009 | 01:50 PM
Bad93Cummins's Avatar
Default Air Dog Install
How hard to do? Any input to an easy way of install? About to order one.
Old Sep 6, 2009 | 02:49 PM
biged681985's Avatar
idk bout on a 93 model, but on a 2nd gen there not super hard, just make sure u have close to an empty tank of fuel when u go to drop the tank. good luck and be safe
Old Sep 6, 2009 | 07:05 PM
Worse part is dropping the Tank.
Old Sep 6, 2009 | 08:20 PM
Red_Rattler's Avatar
High Tech Redneck
Or you can just take the bed off like I did
Old Sep 7, 2009 | 08:38 AM
RSWORDS's Avatar
Very Easy... Here are some write ups.
https://www.dieselbombers.com/5-9l-c...ou-decide.html
https://www.dieselbombers.com/show-t...airdog-ii.html
Old Sep 7, 2009 | 12:49 PM
1st_gen_puller's Avatar
airdog has to much pressure for a VE pump... hope you have already taken care of this... not sure but i read somewhere you can buy what i would call like a limiter to reduce the line pressure.... check into it..
Old Sep 7, 2009 | 01:17 PM
High Tech Redneck
If you run an AD setup from a second grn the pressure is just fine 15-20 psi and if it's still to much you can get different springs for it to drop it more.
Old Sep 7, 2009 | 01:25 PM
RSWORDS's Avatar
Yep A 2nd gen 24v setup is perfect for our trucks. Even the fittings are correct.
The p-pump set-up has to much pressure.
Old Sep 7, 2009 | 09:49 PM
The guy told me he had one for my 1st gen truck, but I have read on air dog's site that you can adjust the pressure.
Thanks guy's for all the help.
Old Sep 8, 2009 | 10:15 PM
tower_ofpower's Avatar
i heard not too long ago that an airdog with an adjustable regulator may have been in the works... i've also read you can get a spring kit that'll adjust pressures... idk what kinda base all of that has... just what i've read
