Fuel Pin Stuck?
Old Sep 6, 2009 | 11:26 AM
HankdaTank's Avatar
Default Fuel Pin Stuck?
Installed a denny t pin and now i can not remove it and it is full of fuel? Help
Old Sep 6, 2009 | 07:06 PM
NadirPoint's Avatar
Try rotating it in the bore while you move the throttle. No reason it shouldn't come out. You are going to have to replace the o-ring on the guide pin now. Common problem with these pins when they let the guide pin out too far, or far enough to booger up that o-ring seal.
Old Sep 6, 2009 | 09:41 PM
tower_ofpower's Avatar
yeah; o-rings dont like hitting spots that it doesnt usually ride on... it doesnt take much to dammage the seal. i'm suprised my full fuel screw isnt leaking it wasn't in that great of shape when i took it out to remove the collar; new o ring and you fuel problem will be solved twisting or rotating the pin while pulling up should set the pin back in the bore so you can get the fuel pin out... NadirPoint is absolutely correct
Dbleo351
Nov 20, 2016 09:34 AM
Jet A Fuel
Tech Article Submission
Jun 5, 2015 03:28 PM
ctjkelley
Jun 3, 2015 06:01 AM
moneypitk5
Feb 12, 2015 11:01 AM
cfarley0210
Jan 19, 2015 06:00 PM
