Used Holset 21CM Exhaust Housing For Sale
Old Sep 5, 2009 | 05:20 PM
DB Admin's Avatar
Banned
Default Used Holset 21CM Exhaust Housing For Sale
$150 Free Shipping
Old Sep 8, 2009 | 02:05 AM
davo79's Avatar
Hey dm what model holset was this off of and is it wastgated or not
Old Sep 8, 2009 | 11:23 AM
DB Admin's Avatar
Banned
it was on an hx35 when i bought it
Old Sep 8, 2009 | 04:43 PM
davo79's Avatar
Goog egts
Old Sep 8, 2009 | 11:12 PM
DB Admin's Avatar
Banned
going to be laggy w/o larger injectors
Old Sep 9, 2009 | 11:07 AM
davo79's Avatar
My new era 370s won't be enough what should I get som 5x16s
Old Sep 9, 2009 | 11:18 AM
DB Admin's Avatar
Banned
just have to try it out , it only takes an hour to take off the turbo and change the exhaust housing
Old Sep 9, 2009 | 09:12 PM
davo79's Avatar
No need to change the exducer wheel or what
Old Sep 9, 2009 | 11:18 PM
DB Admin's Avatar
Banned
Nope just 4 bolts ,
it comes right apart , then you put this on and leave them bolts loose until you get the turbo mounted
Heres a guide i made..
With this guide we have a donor charger so Removal of the charger is not included Refer to the Charger Swap Guide for further information
Completion time: Less than 2 Hours
Here's a 16cm Holset Exhaust Housing
Here's the Exhaust Gasket
Here's the Oil Return Line Gasket
Here's the donor charger
This set up is a Holset HX35W with a Modified 21 Cm Exhaust Housing to fit the newer model Cummins that don't have the clamp style Connection to the down pipe
Separating the charger
Remove the 4 bolts
the 2 rings will then come off this is what they look like
Old Sep 9, 2009 | 11:19 PM
DB Admin's Avatar
Banned
Spray a bunch of the best penetrating oil you can find around the connection of the Exhaust Housing and the Compressor Housing and wait for it to penetrate.
You do not want to separate the two parts violently there is a fragile shaft that runs the length of the turbo and connects the compressor wheel and the exhaust turbine
Bend it and you're done for !
Here it is coming apart
Apart picks below:
Here's the exhaust turbine
Now that its apart take the 16 Cm housing and slide it on over the exhaust turbine
Set one of the rings in place
