h.o cummins
Old Sep 5, 2009 | 04:51 PM
dirt diggler's Avatar
Default h.o cummins
well just wondering what year an what exactley makes it a h.o mines an 01 6sp 4x4 so is this concederd one and what is the diff hp rateing on reg 5.9 an 5.9 h.o trucks thanks
Old Sep 5, 2009 | 05:08 PM
DB Admin's Avatar
Banned
The HO Cummins have the High Output VP44
I think all standard transmission 24V have it and the HX35 12CM instead for the Automatic Trans Trucks have the HY35 9 CM
Old Sep 5, 2009 | 05:25 PM
thanks well do ya have eny idea on fact hp rattings on the h.o an non h.o cummins
Old Sep 5, 2009 | 05:28 PM
2001 ISB engine changes (begins Jan 1, 2000)
235hp / 460 ft. lb. ETC engine installed in 5-speed and automatic equipped trucks
ETC continues to use a 10cm2 HY35
245hp / 505 ft. lb. ETH engine became available with the DEE 6-speed.
ETH returns to the 12cm2 HX35W turbocharger.
ETH receives a higher output fuel injection pump.
Compression ratio is increased from 16.3 to 17.0.
01quadcab's Avatar
235 so 245 ho. the 6 spd was supposed to be the ho and the auto and 5 spd were so trucks.
Old Sep 5, 2009 | 05:36 PM
thanks fellas for the input the vp pump on the h.o still prone on dyeing i suppose
Old Sep 5, 2009 | 07:00 PM
Buckshotmckee's Avatar
Sma't Alec!
The 5spd ETC used the HX35 as well. The HY35 were used on the autos.
Old Sep 5, 2009 | 07:09 PM
dukeboy_318's Avatar
yep, its the design of the VP, plus an HO pump will make less potential hp when bombed then an SO pump because the plungers inside are actually smaller and wont flow as much fuel
Old Sep 5, 2009 | 07:42 PM
well that sucks on the plungers what is the diffrence right now why the h.o is puttin out more power than the so pump?
Old Sep 5, 2009 | 08:51 PM
Look here for the differences:
2001 ISB engine specs
