hp and torque estiment
ive got a 94 12 valve 4x4 5spd. factory it has 180hp and 440 ft-lbs. with the mods in my sig- stock plate all the way forward,star wheel 3 1/2 turns forward and the preboost screw flush with the jam nut, 4" straight pipe and k&n filter only. whats a rough estiment of the power i should be making? thanks
country boy your truck can handle a lot before it starts getting too hot or too much boost. i have exact truck as yours mine is std cab and with a dynamic diesel plate all the way forward, boost elbow and BHAF it would be hard to get it to 1000 degrees and it would push about 38psi. you should grind your plate and get an elbow or plug your wastegate just dont go much over 45psi or you'll have to worry about a head gasket. might even get some DV's and gov springs both are pretty cheap
