KDP, wrong gasket
Old Sep 3, 2009 | 10:49 PM
D Gandy's Avatar
Default KDP, wrong gasket
I just did a kdp repair tonight on an '89 12v for my buddy tonight. He got the kit from XDP and it came with a new seal for the crank and a new gear case gasket. The crank seal fit but the case gasket was all wrong, wouldn't line up with any of the holes. I looked at the paper work that came with the kit and it was listed for a 2nd gen. Is the difference in the gasket that it is for a p-pumped gear case?? He is going to call XDP tomorrow but wanted to check with u guys to see if this was common. ALso, what are u all paying for this kit? He said he paid $90 bucks for it, seemed a little high but then I thought maybe the gaskets were the major price. Just a thought.
Old Sep 3, 2009 | 11:27 PM
94cummins12v's Avatar
the gaskets are what cost the most, as for the gasket the reason there different is not the p-pump its were the vac/powerstering pump are located. when i overhauled my engine they sent me a 1st gen gasket and wouldnt line up
Old Sep 3, 2009 | 11:38 PM
tower_ofpower's Avatar
i've seen the kits for at low as 65 er 69 bucks...
Old Sep 4, 2009 | 08:00 AM
RSWORDS's Avatar
Yeas teh VE and P-Pump kits are different. RTV time.
Old Sep 4, 2009 | 09:03 AM
NadirPoint's Avatar
The best way to make RTV seal on a big, flat surface like that is to assemble it and let it sit for awhile (at least a day, two is better) with the bolts just finger tight. Then snug them down after the RTV has cured some so it actually makes a sort of it's own gasket instead of squeeznig most of it out when you tighten down the bolts.
Old Sep 4, 2009 | 09:26 AM
RSWORDS's Avatar
Thats good advice
Old Sep 4, 2009 | 10:32 AM
mysterync's Avatar
The reason you can find some kits cheaper is they just come with a tube of silicone , not a gasket. I priced one the other day, and the only one right now that comes with the gasket is the BD KDP Kit. If he got it from XDP he probably gave right around 118.00 plus shipping , but they may have figured a discount in somewhere.
Old Sep 4, 2009 | 08:14 PM
PDR Diesel Performance: KDP Kit - 1st Gen
$69.00 +S&H they say it comes with the seal idk if they're just blowin smoke or not
and do the silicone trick with permatex's "the right stuff" it wont compress as much when fully cured like silicone will... i usually use the ultra black on just about everything but if i'm feeling rich i use the right stuff
Last edited by tower_ofpower; Sep 4, 2009 at 08:14 PM. Reason: Automerged Doublepost
Old Sep 4, 2009 | 08:32 PM
mysterync's Avatar
It comes with a "Seal" not a "gasket" . Just like the TST kits, They have a seal and some silcone , No gasket. I dont have a problem with RTV but It'll leak alot quicker than the correct gasket!
Old Sep 4, 2009 | 08:40 PM
it does say timing cover gasket... when ever i do the KDP on my truck i'll get this kit and dig this thread out of the rubble and let ya guys know if they're just pullin your leg
and probably if it comes with the gasket... it isnt a very good one i may just stick with some silicone
Last edited by tower_ofpower; Sep 4, 2009 at 08:40 PM. Reason: Automerged Doublepost
