IPC sensor
Old Sep 1, 2009 | 04:25 PM
tlevan03's Avatar
Default IPC sensor
what are the signs of the IPC sensor going bad? would it cause a abnormal idle? it doesnt happen all the time, but sometimes at astop light i watch the tach bounce around. i hooked up a code reader at work and none were present. thanks
Old Sep 1, 2009 | 04:39 PM
mysterync's Avatar
Abnormal Idle, Jerky throttle, Miss, Oil leaking down the back of the block , Long start times.....You have to remember that the ICP is in control of the HPO system.
Old Sep 1, 2009 | 05:04 PM
tlevan03's Avatar
i havent check for the oil yet. but you hit the nail on the head. so i take it that it is bad and needs to be replaced? anybody know the price on that?
Old Sep 1, 2009 | 05:22 PM
mysterync's Avatar
Big angry hillbilly will drop in before long, It all depends on where it's at? I think on the 05's is in the valve cover but may be wrong! I know you dont ever offer to change one on a 03 truck!
Old Sep 2, 2009 | 02:56 PM
04redstroker's Avatar
the rough idle could also a weak FICM IIRC
Old Sep 2, 2009 | 06:53 PM
Big Angry Hillbilly's Avatar
Valve cover ICP on that one.
IIRC - sensor is PN 4C3Z - 9F838 - AB but i may be wrong on the suffix. Have them look it up by your VIN to make sure you're getting the right stuff.
Rough idle can be caused by a LOT of different stuff on a 6.0. FICM, ICP, IPR, hell, even ratty engine oil can make it idle rough.
FWIW, I'd get it diagnosed at a reputable place, since "trying out parts" on these motors isn't usually a cheap enterprise.
I think the ICP sensor is over a hundred bucks, if memory serves me rightly. If you do end up replacing the sensor on your own, also replace the pigtail harness. Part number for the pigtail is 5C3Z-12224-A.
Old Sep 2, 2009 | 06:55 PM
Quoted for truth
As well - if the ICP is on the valve cover, the oil leaking at the back of the engine won't be the ICP sensor - as others have stated, the ICP sensor on early build trucks is under the turbocharger, on the top of the HPOP cover. They commonly leak due to their proximity to extreme heat.
Old Sep 2, 2009 | 07:12 PM
mysterync's Avatar
I thought about that after I said it, Not to mention the location of the early build ICP sensors is the home of heartache, headache, PIA, the location of all the oil that's ever leaked off your truck, exactly 1 inch in either direction farther than you can reach, not to mention the three known cases of fiberglass poisoning last year came from that general location as well!
Originally Posted by Big Angry Hillbilly
Quoted for truth
Old Sep 2, 2009 | 08:47 PM
tlevan03's Avatar
the oil got changed when the FICM got changed. what else should i tackle? im hooking the computer up tomorrow to run some tests. im sick of the dealer telling me nothing is wrong, but the crazy idle is there. also, the fuel filters are new. thanks hillbilly
Old Sep 28, 2009 | 08:04 AM
carmel's Avatar
can anyone tell me where to get a drawing and location of the ipc sensor for a f 250 6 liter (2004)
