Chevy/GMC Duramax 06-07 LBZ Discussion of Chevy and GMC Trucks with LBZ Duramax Turbo Diesel Engines
Wont start after sitting for a few days...any ideas????
Old Aug 31, 2009 | 01:54 PM
Edge33's Avatar
Default Wont start after sitting for a few days...any ideas????
So the truck has an unusual problem, after it sits for a few days it wont start, it cranks but takes a bit to fire. It doesnt throw any codes either. Im assuming im getting air in the fuel system some how. The drive way has a slight angle but nothing drastic. Any suggestions? Thanks.
The dealer said its not uncommon !!! hmmm i have to disagree
Old Aug 31, 2009 | 02:18 PM
mysterync's Avatar
Sounds like your fuel filter is leaking down. I've seen 4 or 5 do it.
I would change the filter and O-rings, and then look towards the rest of the supply fuel system!
Old Aug 31, 2009 | 03:10 PM
j johnson's Avatar
also look at the water in fuel sencer at the bottom of the fuel filter the drain has been knowen to leak...sometimes it wont leak on the ground but just anuff to let in air...hope this helps!!
Old Sep 1, 2009 | 05:05 PM
Edge33's Avatar
Thanks guys ill check into both...
Old Sep 7, 2009 | 12:32 PM
BriteWhiteRam's Avatar
even just not getting the fuel filter tight enough will do it, also, try to reprime the system and see if that helps
Old Sep 7, 2009 | 03:46 PM
mysterync's Avatar
If it's more than a filter, it could be a CP3
moparisthebest
23
Oct 15, 2015 12:13 PM
Cavnar
Sep 9, 2015 07:18 PM
IGOU
Mar 8, 2015 04:25 PM
ronstop
Feb 26, 2015 09:48 AM
carid
Diesel Bombers Sponsors
Nov 18, 2014 06:49 AM
