07 5.9 Engine Cuts out at higher rpms
Old Aug 31, 2009 | 09:28 AM
RINEHOLT98's Avatar
Default 07 5.9 Engine Cuts out at higher rpms
I have an 07 5.9 cummins and when I am into the throttle the engines cuts on and off like someone is flicking a switch. it starts around 2500 to 3000 rpms. I changed the fuel filter and no difference? Thanks for any help on this.
Old Aug 31, 2009 | 12:48 PM
redcummins04's Avatar
do you have a fuel pressure gauge? could be the lift pump..maybe rail pressure drop too
Old Aug 31, 2009 | 05:39 PM
RINEHOLT98's Avatar
No, I dont have a gauge. I went to start it today and the engine died like it was running out of fuel. I got these codes P0513-invalid key shim, p0234 - Turbocharger overboost, p2509 ECM/PCM Power input signal intermittent, and p0251 - injection pump fuel valve feedback. Got no clue what is going on now.
Old Aug 31, 2009 | 05:45 PM
wildbill's Avatar
P0251 is related to the FCA (fuel control actuator). It's mounted on the back of the CP3 with 3 small screws. A new one from Cummins is about $120-$150.
Old Sep 1, 2009 | 10:04 AM
RINEHOLT98's Avatar
Figured out that the key fob has a microchip in it. I used a copied key and after you start the truck it senses no microchip and kills the engine. The truck still cuts out when I am getting on the throttle though. I will look at the FCA. Thanks Wildbill!
Old Sep 7, 2009 | 07:45 PM
cummin_un_glued's Avatar
FormerVendor
i'm really interested in what you find out my 07 5.9 just started doing the exact same thing on the way home from terre haute except i have no codes and i just replaced the injectors today and that did not fix it
Old Sep 8, 2009 | 05:30 PM
PaulW's Avatar
My 03 is doing it too, but it's doing it around 2000 rpm with the Edge Juice w/A on any setting.
Previous owner had the in-tank lift pump retrofit, but no idea on the mileage on it.
I have a BD Flow-Max on order, and hope to have it in hand this week.
I'll keep you posted.
Old May 16, 2011 | 07:09 PM
hydroshok's Avatar
I had this happen to me but all the lights came on like I was trying to start the truck. I have read where it has happened like you are saying. I turned the key on for 10min then off for 10min the back on for 10min and that seemed to work for a while. The stealership offered to reprogram my keys for free after that so I don't know if that will really fix it, but worth a try. It is a simple fix. I had no codes for a long time then the skim key code was present. Let me know if you try it...
burndiesel
10
Feb 7, 2023 01:15 AM
klein444
Jun 20, 2015 11:48 PM
metal_miner
Diesel Engine Conversions
Dec 23, 2014 11:40 PM
Lee Chisholm
Dec 3, 2014 05:58 PM
hunt4beer
Nov 15, 2014 09:06 AM
