whats wrong???
Old Aug 30, 2009 | 05:21 PM
Dan.tha.Cummins.man's Avatar
Default whats wrong???
sometimes when i turn sharp going really slow it feels like my tires are rubbing(i know for a fact that they arent) . something is grabbing and kinda jerkin. it is hard to describe and it seems to do it worse with a heavy trailor hooked up. it does it in reverse and drive. thanks in advance.
Old Aug 30, 2009 | 05:40 PM
bryson's Avatar
I'd bet you have a bad front axle u-joint...
You sure it isn't in 4wd?
Old Aug 30, 2009 | 06:35 PM
dustys24valve's Avatar
The stick or switch might not be in 4wd but the front end still might be locked on you
Old Aug 30, 2009 | 06:37 PM
luke46's Avatar
sounds like your axle disconnect is stuck
Old Aug 30, 2009 | 06:50 PM
diesel pap's Avatar
Site Sponsor - Mighty Diesel
axle joints do that when they are bad.
Old Aug 31, 2009 | 09:41 PM
well im positive the stick is not in 4WD and o know that the front tires aint spinnin in gravel. you know what i mean? the truck has 90k miles on her. do you thinks i should just replace the axel joints anyway and see if that fixes it? couldnt hurt, right?
Old Aug 31, 2009 | 11:31 PM
bryson's Avatar
Don't replace the joints if they aren't bad... they can be a pain in the azz. Just jack the front end up one corner at a time with the steering wheel turned, and spin the tire. If the joint is bad, you'll notice noise or grabbing right away. Easy.
Old Sep 1, 2009 | 12:46 AM
Any type of grinding noise?
Old Sep 2, 2009 | 09:12 AM
naw no grinding just a grabbing feeling. i would jack it up today and look at it but i got thrown off my horse yesterday evening and i can barely walk now.
jjbced
Jul 19, 2015 10:03 AM
gumborancher
Apr 24, 2015 01:25 PM
Bob V
Apr 6, 2015 11:02 PM
nelly559
Feb 2, 2015 08:19 AM
cutthroatxxx
Nov 16, 2014 09:11 PM
