EGR/DPF Quick Question
Old Aug 30, 2009 | 12:31 PM
DanS's Avatar
Default EGR/DPF Quick Question
If you dont mind seeing the check engine light are there any other issues or problems that arise from EGR/DPF delete without the tuner. Or is the tuner solely for the purpose of making the light go off? Someone said something about it limps the truck. Whats the deal. Can you do it without the tuner if you dont mind the light?
Old Aug 30, 2009 | 12:40 PM
cashwheel's Avatar
As long as you use the sims at the sensor locations in the exhaust you should have no problems with limp mode. It's well worth it for the MPG gains, if you can live with the CEL. Most delete kits come with the sims.
Old Dec 7, 2009 | 03:27 PM
a1953mdl's Avatar
I have the egr unplugged and blocked, straight piped from the turbo back except for the o2 sensors (re-installed them). With home made sims.
I have a cat full warning on my overhead with occasional dinging. Plus the cel.....but I'm getting a solid 5mpg better also.
I haven't figured out why my I have the warning. I tried with the pressure sensor hooked up and no hoses and also unplugged with the sim resistors installed.
No limp for the last 5K miles.
Saving up for a tuner.
Lee
dutchsupreme
Diesel Engine Conversions
May 25, 2015 08:48 PM
May 8, 2015 11:10 AM
97 stroker
Ford Powerstroke 08-10 6.4L
Feb 18, 2015 03:25 PM
12thman
Jan 20, 2015 03:22 PM
CumminsCrazed
5.9L 24V Performance
Oct 27, 2014 09:02 PM
