OIL BLOWING OUT OF TIMING COVER,COOLANT BLOWN FROM REAR FREEZE PLUG
Old Aug 29, 2009 | 05:03 PM
dtromo's Avatar
Default OIL BLOWING OUT OF TIMING COVER,COOLANT BLOWN FROM REAR FREEZE PLUG
JUST GOT MY SMARTY TUNER 3 DAYS AGO AND WAS EXPERIMENTING. I HEARD THAT THE TNT-R ON THE 03 HAS RAIL POP. JUST HAD TO CHECK THIS OUT. WAS DRIVING AROUND WITH THE SETTINGS ON SW#5 T2 TQ3 R1 MP-8 ABOUT 70%. THIS TUNER IS AWESOME! THEN PUT SETTINGS ON SW#7 T2 TQ3 R1 MP-8 70%. THIS PRODUCED RAIL POP UNDER LOAD. I PULLED OVER TO CHANGE THE SETTINGS BACK AND SMELLED ANTI FREEZE. WHEN I CHECKED IT OUT THERE WAS OIL AND COOLANT ALL OVER. THE COOLANT FROM THE BACK AND THE OIL GURGLING FROM THE FRONT TIMING COVER AREA. I KNOW ABOUT COOLANT BY-PASS WHEN RUNNING HARD UNDER LOAD, BUT THE OIL BLOWING OUT UNDER LOAD? IS THIS JUST BAD LUCK OR IS THERE A MOD TO PREVENT THIS? OR IS IT AS SIMPLE AS A CLOGGED BREATHER OR A BAD GASKET? ANY INSIGHT WOULD BE HELPFUL.THANKS.
Old Aug 29, 2009 | 05:37 PM
mysterync's Avatar
first of all it could be a blown head gasket which seems most like what your dealing with. If oils blowing out the timing cover could be a busted block or hole in a piston. Sounds like the crankcase and cooling system are pressurized which is probably a head gasket. Did you let the truck warm up before bringing the boost up?
Old Aug 29, 2009 | 06:40 PM
dtromo's Avatar
the truck was warm. didn't go wot because of rail pop. i think it went to 38psi. didn't start gushing till i stopped. this sounds pretty ugly.
Old Aug 29, 2009 | 09:28 PM
06 DIESEL's Avatar
Sounds like a HG (Head Gasket). They are easy enough to change yourself, I did mine when my truck was still technically under warranty. I see that you are already studded, are you sure that they were still torqued properly? I would pull the head, send it to be checked for trueness, decked if needed and then put it back together.
Old Aug 29, 2009 | 10:06 PM
mysterync's Avatar
Could have been high timing or an injector problem that caused the gasket failure. Is your head ringed?
Old Aug 29, 2009 | 11:37 PM
Camotanker's Avatar
timing and boost. pop goes the...
probably just a head gasket. its common to squirt oil and/or coolant. if you lift the head and escapes from cylinder 1, it could shoot oil out the front towards the fan. been there done that.
becareful bro... moderation!
Old Aug 29, 2009 | 11:59 PM
sidekick's Avatar
that sucks sounds like h.g.
Old Aug 30, 2009 | 12:44 PM
dtromo's Avatar
thanks for all the info guys:U
Old Sep 5, 2009 | 11:40 AM
XLR8R's Avatar
Dude, you maxed out your 555 motor's fuel timing to 21* and added at least 3* more effective timing from the MP-8 through the re-entrant (flatter) injectors!
Sounds like you found out the hard way that's an easy way to roach an engine... bet the HG is wasted for sure - hope none of the coolant got to the bearings.
JustAnother_cummins_guy
Nov 10, 2014 09:44 PM
