need more power
Old Aug 29, 2009 | 10:46 AM
rollincoal12valve's Avatar
Default need more power
i need more power for little$$$
any ideas?
i have exhaust, gauges, intake and fuel plate slid full forward
Old Aug 29, 2009 | 11:09 AM
tower_ofpower's Avatar
for 40ish maybe less. you can get a boost elbow for the feed line to the wastegate... you can bring your boost up abit by adjusting it. alls it is, is a spring loaded ball. get some sheet metal and make a heat shield for the BHAF it runs kinda close to the turbo and sucks alot of heat, also tune the AFC. how beefy is your transmission? some other guys will probably chirp in and tell you to grind your fuel plate to a certain profile
i dont know much about the fuel plates so i'm not going to give ya any advice there
Last edited by tower_ofpower; Aug 29, 2009 at 11:09 AM. Reason: Automerged Doublepost
Old Aug 29, 2009 | 12:21 PM
where can i get a boost elbow?
also
i am in the process of making a heat shield.
trans is stock
how do i tune the afc what else can i do?
Old Aug 29, 2009 | 01:03 PM
tuning the afc involves turnign the starwheel (it can be axcessed via the allen head plug ontop of the housing... screw it torwards the radiator so it is more sensitive to boost and allows fuel to come on faster... the smoke screw (under the tin cap) on the back of the AFC housing adjusts where the AFC sits... you turn it in... it'll hold the AFC forward and sets at what point fueling starts. maybe a turn and a half or slightly better on the starwheel and.... 2ish turns on the smoke screw... should put a smile on your face. since there isnt an "actual tune" its something you just have to mess with. as for the boost elbow... some of the sponsors websites have them. i dont know of any off the top of my head so just dig around and with a stock transmission... turnin the truck up is abit iffy just be easy with the go peddal... they dont like much more power over stock, atleast from take off... that's where everything is put on the hardest bind.
Old Aug 29, 2009 | 01:57 PM
davo79's Avatar
Screw cuttin the plat just take it out hahahahaahaaa. Ok don't do that unless you got a spare trans sittin around as for more power tower of power nailed it right on the head the one thing he didn't say was blockin the wastegate off or one trick I found worked and you don't gain much but is well worth the time is adjusting the trans bands that doesn't get more power it just puts the power you have to the ground more efficiantly
Old Aug 29, 2009 | 03:47 PM
94 12valve's Avatar
was this a reference to another thread?
there is more you can do to the afc like changeing the srpring and moding the afc arm along with what was already said
Old Aug 29, 2009 | 05:41 PM
lay of the stones 94 12valve... i was miss informed about the functioning of the governor; made sense to me but yeah; i dont say anything unless i feel confident in saying it if i'm wrong; no big i'll admit it and keep from telling others the wrong info
as for blocking off the wastegate... the boost elbow can do the same it's just more expensive than folding the tube over and putting a zip tie on it; but i prefer some adjustability... no waste gate function can increase the chances of compressor surge...
Old Aug 29, 2009 | 08:05 PM
Ive got a Edge Boost Elbow here that I can send ya for $10 plus shipping.
Old Aug 29, 2009 | 08:36 PM
lodal cummins's Avatar
what is the term slide afc full forward? is this sliding the afc on the rod all the way towards front of motor? i missed that when i tuned mine!!!!
Old Aug 29, 2009 | 08:44 PM
the AFC housing has ovaled holes... you can take the 4 screws loose and slide the whole housing just like you did the fuel plate
