injectors
Old Aug 29, 2009 | 12:01 AM
toyhauler's Avatar
Default injectors
i have a 06 with 60,000 mi. it has a diablo sport tuner , intake, boost fooler and cfm intake elbow. i have already gone threw 2 # 1 injectors and now it seems i have another one that has gone bad . my question is are the stock injectors really this bad or am i doing something wrong? Any help would sure be appreciated thank you
Old Aug 29, 2009 | 01:03 PM
dorkweed's Avatar
From: "The Peoples Republic of Illinois".....behind enemy lines
There is a reason why quite a few around the forums refer to it as "Dia Blow"!!!
Old Aug 29, 2009 | 03:10 PM
mysterync's Avatar
Very true, The Diablo will call for high rail pressure and cause failures. What kind of Rail pressure are you seeing?
Old Aug 29, 2009 | 03:53 PM
Added Rail Pressure can cause the injector tip to crack causing big issues.
Old Aug 29, 2009 | 06:37 PM
AHolt's Avatar
What type of fuel filter are you using. That seems to be another thing,
causing problems with these injectors. Bosch calls for a 2 micron filter.
The stock filter is 10 micron. Between pressure and filter that would do it.
Old Aug 29, 2009 | 07:29 PM
toyhauler's Avatar
not sure how much pressures it runs ,but diablo says that it doesnt increase pressure. the injector is leak so much fuel it fill the crank case with diesel. i never throw fuel rail pressure codes so i assume that the pressure is not to high.
Old Sep 1, 2009 | 06:03 PM
toyhauler's Avatar
Now diablo says it does add pressure. How much pressure is to much for stock injectors?
Is there a better programmer for towing and some small playing around? thanks for your guys help...
Renteria1217
19
Oct 13, 2015 01:36 AM
Militant83
For Sale
Mar 18, 2015 03:34 PM
klein444
Mar 8, 2015 11:42 AM
nate379
For Sale
Feb 15, 2015 03:23 PM
nate379
For Sale
Feb 9, 2015 08:27 PM
