head gasket
Old Aug 27, 2009 | 10:57 PM
1st_gen_puller's Avatar
Default head gasket
i cant keep head gaskets in my truck to save my life... any advice welcome... really interested in someone with knowledge on copper gaskets????
Old Aug 28, 2009 | 12:06 AM
94cummins12v's Avatar
get some head studs that will help
Old Aug 28, 2009 | 12:09 AM
wildbill's Avatar
Have the head and block checked out for warpage also.
Old Aug 28, 2009 | 12:15 AM
ya definatly do that, easy to do with a long straght edge and feeler guage, the heads warp easy if to much heat
Old Aug 28, 2009 | 09:37 PM
just had head completely machined and i have head studs...
anybody have any input... and thanks guys...
Last edited by 1st_gen_puller; Aug 28, 2009 at 09:37 PM. Reason: Automerged Doublepost
Old Sep 1, 2009 | 07:48 AM
So noone has any ideas???
Old Sep 1, 2009 | 10:39 AM
mysterync's Avatar
Are you doing re-torque after a few heat cycles? What are you are you bringing your studs to? 125ftlbs? Letting the truck warm up before boosting it?
Old Sep 1, 2009 | 10:55 AM
2500HeavyDuty's Avatar
/me moved
Old Sep 2, 2009 | 08:26 AM
shop installed it last time i did it this time going to 140lbs warms every time 5 mins before moving then to 200 degrees before any boosting.. every time..
Old Sep 2, 2009 | 12:17 PM
mysterync's Avatar
I would say you have a straightness issue or the sequence in which your tightning the studs is incorrect. Are you using moly lube on the studs and washers before torque?
