waste gating?
Old Aug 26, 2009 | 09:25 PM
DieselPerformanceGuy's Avatar
Default waste gating?
How do you waste gate a turbo on a first gen.
like say if you got a 12cm wg exhaust housing are all the parts there you need or will i have to do somthing else?
Old Aug 27, 2009 | 12:06 AM
tower_ofpower's Avatar
ypu have to get the 12cm housing that is wastegated... (it's integral to the housing) and i'd stick with a 14cm IMO it'll keep spool up there; but also flow enough to keep everything cool... 12cm is abit restrictive with pump mods and injectors
also a heads up... by the time you buy everything to update the H1C your just afew bucks shy of a really nice used turbo... and with that you can get a 2nd gen (wastegated) use an HX40 downpipe and since it's 4" it'll increase torque and spool up plus mount up with your bully dog exhaust nice and easy. but i do believe that a replacement wastegated housing lacks the wastegate actuator...
Last edited by tower_ofpower; Aug 27, 2009 at 12:06 AM. Reason: Automerged Doublepost
Old Aug 27, 2009 | 01:32 PM
ok thanks, so a 14 cm you can get without a wg
Old Aug 27, 2009 | 03:01 PM
yep, that's the way i'd go... with a 60 er 62mm inducer and housing... you can make the H1C a pretty nice turbo but it then makes the shaft the weak link... as stated before; after the upgrades you wouldn't be too far off... talk and deal with the right people you can get some nice stuff for pocket change compared to new turbo's... RSWORDS picked up his turbo for 250 bucks if i recall correctly....
Old Aug 28, 2009 | 10:50 AM
wow he sure knows hot to deal then.
i had another question can a 2nd gen after market turbo fit a first gen, like a complete bolt up no custom fitting.
Last edited by DieselPerformanceGuy; Aug 28, 2009 at 10:50 AM. Reason: Automerged Doublepost
Old Aug 28, 2009 | 12:33 PM
NadirPoint's Avatar
Aftermarket turbos aren't necessarily "Dodge-gen-specific."
Old Aug 28, 2009 | 01:24 PM
RSWORDS's Avatar
exactly.
I'm running a "2nd gen" Silver 62 on my 1st gen.
Old Aug 28, 2009 | 02:13 PM
sweet i'll try that thanks guys
vin_diesel
Mar 1, 2016 01:43 PM
vin_diesel
Sep 15, 2015 11:25 AM
six speed
Sep 14, 2015 09:19 PM
