Rack Plug
Old Aug 26, 2009 | 07:49 PM
smoken's Avatar
Default Rack Plug
Hi, can anyone tell-show me where this 2095 rack plug-mack plug that I have been reading about goes? Thanks
Old Aug 26, 2009 | 09:56 PM
ltr450's Avatar
i think it goes on the front of the pump so that the fuel rack can go forward more
Old Aug 26, 2009 | 11:15 PM
oglejust's Avatar
yep it goes on the front of the pump in between the pump and the timing case. to install it u either need to slide the pump back or grind the timing case, i ground the timing case... dont be scared to grind... theres a lot more material that u think, i gained 3 lbs of boost at top end... thats about all i noticed.
Old Aug 27, 2009 | 12:10 AM
94 12valve's Avatar
my vote is to slide the pump ... the rack plug wont do anything if you plate/afc set up wont allow it
Old Aug 27, 2009 | 12:18 AM
94cummins12v's Avatar
ya definatly slide the pump take the 4 bolts off and it slides back about an inch, just enugh to put the plug in
Old Aug 27, 2009 | 10:09 PM
392hemix's Avatar
If you slide the pump, do you have to adjust the timming? cause alot of guys don't have the tools or know how to adjust the timming in these trucks...
Old Aug 28, 2009 | 12:04 AM
no you dont have to re-time the pump your just sliding the pump back the gears still stay in the same position
Old Aug 28, 2009 | 10:20 AM
Hammer's Avatar
If your going to break the pump shaft loose and slide the pump out for install of the rack plug then I would HIGHLY recommend you time the motor again.Better to do it no while your there with the truck apart than have to go back and redo it.
Also...
If you do this rack plug install this way,by sliding the pump out,then you should get a new pump washer to ensure that the timing will not slip once you have timed the motor again.By reusing the same washer you are asking for nothing but problems......Andy
Old Aug 28, 2009 | 12:05 PM
94 12valve's Avatar
Also...
I agree ... I follow what your saying 94cummins12v but right after the gear comes off I have had the pump rotate enough to throw the old timing
Metz1234
Mar 3, 2016 10:20 PM
94chevy6.5
Tech Article Submission
Jun 16, 2015 12:45 AM
ajwright64
Feb 4, 2015 09:36 PM
norcal6.5
Dec 7, 2014 07:04 PM
wpg6.5
Nov 19, 2014 04:56 PM
