I need some help with my cummins, throwing codes P0236/P0237/P0238 and same in PD
Old Aug 26, 2009 | 07:00 PM
spike7ss's Avatar
Default I need some help with my cummins, throwing codes P0236/P0237/P0238 and same in PD
On my way home from work, stopped to wash my truck off. When leaving the car wash I went to go and there was limited power. The truck showed 1800 EGT and defueled. So I eased up and the temp came down a bit and the power came back, but only momentairily. Even at idle the truck wanted to be over 1800F so I shut it off.
I took out my edge ez module and put a new clean air filter on, but the codes are still there, even when I clear them with my mac scanner, they keep coming back. I get a P0236, P0237, P0238, and P0236PD, P0237PD, and P0238PD
Just so everyone knows, Its a 05 dodge 5.9 auto and I have a AFE stage 2 intake, 4 inch turbo back diamond eye exhaust, Edge Ez, Bully dog outlook monitor. Everything else is stock. I use this truck for daily driving and towing.
If anyone has any info I would be much appreciated
Thanks!!!!
Old Aug 26, 2009 | 07:02 PM
wildbill's Avatar
Lemme look er up. Be a minute.
Old Aug 26, 2009 | 07:04 PM
wildbill's Avatar
P0236-MAP SENSOR TOO HIGH TOO LONG
P0237-MAP SENSOR VOLTAGE TOO LOW
P0238-MAP SENSOR VOLTAGE TOO HIGH
Try and dry the connection out.
Old Aug 26, 2009 | 08:10 PM
spike7ss's Avatar
Will try that out and see what happens. Thanks Wild bill
Old Aug 26, 2009 | 08:15 PM
wildbill's Avatar
No problem!!
Old Aug 26, 2009 | 11:23 PM
spike7ss's Avatar
Took the map sensor plug off and found it to be corroded, gave it a spray and some dielectic grease and it seems to have smartened up. It wierd becasue on the weekend my truck sat for 4 days while out camping, I got the same codes, but was able to clear them and away i went.
Old Aug 26, 2009 | 11:25 PM
wildbill's Avatar
The little extra humidity must've done it in.
