injectors or worse?
Old Aug 25, 2009 | 04:38 PM
83cucv1028's Avatar
Default injectors or worse?
i'm a new member and i have an 04 dodge 4x4 that is blowing smoke and oil pretty bad, about 2 quarts every 500 miles. constant smoke from the crank case vent tube, and if you take off the oil filler cap when running it looks like a train puffing out smoke. lots of black smoke when you get on it. engine has 240,000 miles on it. taking it to the shop for a compression check, does it sound like an injector problem or something more expensive?
Old Aug 25, 2009 | 05:38 PM
Do you have any Diesel Fuel in your Engine Oil?
Old Aug 25, 2009 | 06:02 PM
83cucv1028's Avatar
don't think so, oil doesn't smell like diesel
Old Aug 25, 2009 | 06:06 PM
06 DIESEL's Avatar
Sounds to me like your rings might be bad. Time for a rebuild.
Old Aug 25, 2009 | 08:50 PM
tower_ofpower's Avatar
240,000 and needa rebuild... mannnn what have they done with these newer engines good luck man and i wish you the best
Old Nov 2, 2009 | 12:17 AM
bobinyelm's Avatar
My '03 w/ 109k was making blow-by. Pulled the head and there was a 5/15" vertical gouge dead front in #1 cylinder about 0.015"-0.020" and a vertical scratch in #6.
Truck never pulled anything heavy, and was running smoothly and perfectly right up to the head pull.
Cummins tech says LOTS of low mileage engines (just over 100k) have #1 and #6 cylinder problems-no good reason that anyone is aware of.
Bob
Old Nov 2, 2009 | 05:43 AM
06 DIESEL's Avatar
The main reason for this is high idle times. At 700-800 RPM the truck does not burn all of the fuel that is injected and it washes down the cylinders. This is one of the reasons that they made it possible to set a manual high idle in the third gens with the cruise control. Every time I am going to be idling for more than a minute I kick on the high idle in mine.
Old Nov 2, 2009 | 08:52 AM
cerberus60's Avatar
Bob
Oh there are good reasons for it, usually too much idly and not enough worky. Long idle times will KILL an engine in a relatively short time. Been that way since diesels have been built. All they have to do is compare the engine hours to miless to see where the problems are.
Old Nov 2, 2009 | 02:44 PM
TXAustin's Avatar
Yup, rings are bad time for a rebuild... welcome to the club!
Old Nov 2, 2009 | 04:44 PM
mysterync's Avatar
Sounds most like rings!
