Abs problems 1997 3500 4x4
Old Aug 25, 2009 | 12:15 PM
prromine's Avatar
Default Abs problems 1997 3500 4x4
Here is the problem: Every once in a while the brake pedal will be hard to push. Then it will push like normal after the Abs and brake light come on. Sometimes I can hear a clicking noise from under the dash at random times (lights off). I have changed the speed sensor in the rear axle and today I am going to buff the pulse rings on the front axle. The front wheel bearings feel tight. When I shut the truck off and restart it the light will be off.
Paul
Old Aug 25, 2009 | 08:32 PM
lunk's Avatar
check the front sensor wires mine were rubbing the rim and rubbed through also check all your vaccumm lines, my line to the cruise controll broke (under driver side battery) . once fixxed my steering and braking got easier my abs and brake light went off. also i replaced the brake light switch. hope that helps
Old Sep 4, 2009 | 05:27 PM
dirt diggler's Avatar
well i guess i should have looked a little further on the post im haveing sorta the same prob
Wyattbyrd
5.9L CR Performance
May 28, 2015 10:32 AM
TKulak
Mar 26, 2015 10:27 PM
DIESELDENT
For Sale
Dec 19, 2014 06:53 PM
Jackson Gregory Scott
Nov 1, 2014 04:06 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
