Need some answers
i have a 24 valve cummins and i have a crack in my block and i have a 12 valve block. do you recomend me putting the 12 valve block in with the 12 valve pump and keeping the 24v heads? is anyone running this? i've heard this is the best setup. Thanks
it has been done but takes some machining to get everything lined up right, if you have the 12 valve motor, id say swap the whole thing into your truck and run the p-pump, much better setup, much less work
Aug 25, 2015 07:30 PM
piledrivingman
Mar 2, 2015 09:18 AM
