Boost installation
Old Aug 24, 2009 | 09:14 PM
91cumminsboy's Avatar
Default Boost installation
ok well i got a boost guage outta another truck and i dont know how exactly to hook it up and anything thing would help pics expessially thanks
Old Aug 24, 2009 | 10:15 PM
Free89W350's Avatar
I don't have any picks but if you look at the driverside of the engine right at the intake elbow just below that on the head itself there is a 1/8" pipe plug. If your truck is intercooled you will already have a hole in the throttle linkage bracket if your truck is non intercooled you will have to take the bracket off to get to the plug and while it is off you'll need to drill a hole in it so the line can go through. What I did was put a 2" long piece of 1/8" pipe on and put the line on that. It is actually really easy.
Old Aug 24, 2009 | 10:27 PM
So since my truck is intercooled i dont have to drill a hole sorry im a dummy when its comes to this stuff
Old Aug 24, 2009 | 10:35 PM
TTipsword's Avatar
i just drilled and tapped a hole in my intake horn. then drilled a hole in the fire wall an used a rubber fittng in the hole as to not have the boost line rub on the bare metal.
Old Aug 24, 2009 | 10:37 PM
tower_ofpower's Avatar
well the intercooled non-IC'd truck thing isnt 100% true since the 89 already has the hole in the bracket. different years different designs that is all; but it is probably more true than false. anyways; he's spot on... 1/8 npt hose barb; run the line to your gauge. you can get the small diameter hard plastic line at just about anyplace that sells gauges. if your gauge does use this type of line... snug the fitting then 1/8-1/4 turn... it doesnt take much to seal the ferrule... if your gauge has a hose barb on it use some vinyl tubing... 3/16 is good for like 50 psi, flexible and durable, pretty cheap too
that works too... could have just used the factory supplied hole in the head but if it works for ya then awesome rubber grommet is a good idea too
Last edited by tower_ofpower; Aug 24, 2009 at 10:37 PM. Reason: Automerged Doublepost
Old Aug 24, 2009 | 10:54 PM
Free89W350's Avatar
My 89 had no hole in it that is why I had to drill it out but every IC truck I have seen has it. It's almost like the factory wanted you to put a boost guage in the truck.
Old Aug 25, 2009 | 09:37 PM
hmmm maybe i got a fluke... no idea; it used to be my aunts farm truck... they ran it into the ground i picked it up cheap and i'm redoing it... 137,000 or so on it... the old girl is barely broken in! but they had the cuddy hard plastic line hooked up to it and i kep crushing the ferrules so i got rid of the hard plastic line and ran the vinyl... works great for me.
on a second thought maybe they drilled it... idk
Last edited by tower_ofpower; Aug 25, 2009 at 09:37 PM. Reason: Automerged Doublepost
Old Aug 25, 2009 | 10:06 PM
ok well i got the gauge in thanks alot to all of you wat kinda boost should i be getting with a completley stock truck except exhuast and electronic lift pump
Old Aug 25, 2009 | 10:10 PM
black02cummins's Avatar
hey man it aint that hard ....... i done all of my gauges myself...... this is what you are gonna need.... well let me know what ya got..... such as the boost line and the fitings.... if not i will help ya get it squared away......
Old Aug 25, 2009 | 10:56 PM
