turbo talk
Old Aug 24, 2009 | 12:44 PM
cummins_guy's Avatar
Default turbo talk
Ok, this is what I can find out about all the turbo's that everyone is talking about
HT3B = NT855 is the engine that this turbo goes on, I'm assuming you would not use for a single set up? (part# 3801613)
HX35 = 6BTA out put range 100 280 hp good for a single set up
H1E = 6CTA 8.3 LITTER) the only thing that i can find out that this is the same as a hx40 good for up to 400hp, but I also read that the shafts are junk.
ST50 = KT-1150 K19 ENGINE ) good for 1100 hp
H1C = 6BT 5.9L GOOD FOR UP TO 250 HP
WH1C= 6CT 8.3L same as a HX40 GOOD FOR 400HP
the turbos that I have are ST50, H1C, WH1C, H1E, AND HX30
The questions is, what would be a good twin set up for 400 hp, i just want it to spool really fast. I was thinking of putting on the hx30 and a h1e,
going on a 93
Old Aug 24, 2009 | 04:13 PM
RSWORDS's Avatar
a WH1C is just a waste gated H1C. Its more like a HX35 then a HX40.
How much power you looking to make? A HX30 over a H1E wont support alot of power but will be quick to spool.
Old Aug 25, 2009 | 11:38 AM
I,m just not really sure what I want to do with this engine, just messing around with all the turbos to find out which is better or worse,
not sure if you guys know about this, dont say i never brought anything to your birthday party.
search
Old Aug 25, 2009 | 11:52 AM
RSWORDS's Avatar
well without a goal its kinda hard to pick out a turbo set-up.
Towing? Comp only? High RPM? Low RPM? all these play a role in the turbo set-up.
avatardvr
18
Aug 8, 2019 12:38 AM
Finn92
Feb 24, 2015 10:41 PM
n2brk
Feb 21, 2015 09:05 AM
tumble72
8
Nov 27, 2014 10:31 PM
GreenDieselF
Oct 20, 2014 02:05 PM
