Clutch Confusion...
Old Aug 23, 2009 | 11:48 PM
tdiezel's Avatar
Default Clutch Confusion...
It may take a while but I eventually want to get a new clutch. First im doing my new CP3, exhaust, and gauges. Then I want to get a clutch before I get a smarty and either some new injectors or nozzles to push the fuel. I have been looking into South Bend or Valair. I was set on a SB but from what I can find out their 450hp clutch is more for the street and mine will be a daily driver but when I get everything I want to be able to put my power to the ground and it will definitely be more than 450hp and im happy to say im coming up on that quickly. Valair says their clutches are good up to 800hp which seems like what I would want. But I wont have that much power for a long time or possibly ever in this first diesel truck of mine. I want to eventually push around 750-800 at the most. Could I get some help on choosing a clutch that would be good for what im looking for. I need something that will functionally work with my lower end power until I crank it up but also allow me to push more power and have the clutch be able to handle it. I understand I may have to upgrade in stages which is fine. I also am curious about the warranty on both clutches. I have heard people say that if your SB clutch cant hold the power, SB will upgrade your clutch for free but I don't really buy that. All help is greatly appreciated!
Old Aug 23, 2009 | 11:52 PM
If you dont tow much then you could go with a Valair Full Ceramic Single Disc rated @ 600hp. This is the strongest single disc on the market. Or a Valair Dual Disc 3850# Ceramic Button rated @ 850hp. It really depends on how you use your truck.
Old Aug 23, 2009 | 11:59 PM
tdiezel's Avatar
I dont really tow with it. I basically want to have a lot of horsepower to race and run at the track a couple times a month but also dont want to break anything at the moment. I will buy another truck later for towing but have no real purpose for it at this time. I could tow to earn some extra money with my grandpa and his friends once in a while but not more than probably once a month or less.
Old Aug 24, 2009 | 12:00 AM
If your budget allows id get a Valair Dual Disc.
Old Aug 24, 2009 | 12:09 AM
tdiezel's Avatar
Im sorry for asking but I would like to learn and understand. What does the dual disc gain me? Whats the difference between a single disc and dual disc? How do they apply to performance driving and towing?
Old Aug 24, 2009 | 12:11 AM
94cummins12v's Avatar
the dual disks is two disks stacked together to give you more holding pressure for more power and heavier loads and is alot less grabby than a giant cermic single, backing 20k with a ceramic single will give you a headache after 80'
Old Aug 24, 2009 | 12:29 AM
tdiezel's Avatar
So a dual disc would be my best bet probably for what I want to do?
Old Aug 24, 2009 | 12:31 AM
if you want something that will last along time, if you are hualing alot and have alot of hp the a dual is definatly the route to take, if funds aloow you to thogh. i really need a dual for my truck but having to buy the 1 3/8 input shaft its whats keeping my from doing it
Old Aug 24, 2009 | 12:33 AM
tdiezel's Avatar
Well I have a 6spd manual. Would I also have to buy an input shaft as well? How does that work?
Old Aug 24, 2009 | 02:54 AM
Nope our 6spd's already have the larger 1 3/8 input shafts.
