passenger light not working...
Old Aug 22, 2009 | 07:06 PM
wisconsin redneck's Avatar
Default passenger light not working...
so im in the process of replacing my head light bulbs... the passenger hasnt been working for a while... the blub was blown and i just decided to replace them both... so the brights on the passenger light work... but not the non brights... its not the bulb because i tried interchanging them and the other did the same thing does nybody no what is wrong?? thanks
bob rafferty
Old Aug 22, 2009 | 07:14 PM
Red_Rattler's Avatar
High Tech Redneck
Chaffed wires? Dirty/corroded contact points? Blub loose in the socket? When you have the socket out of the housing with the blub in it and lights on wiggle it around and see if she fires up.
Old Aug 23, 2009 | 09:22 AM
yeh when i wiggle it... it flikers on and off... so the BIG question is........... how do i fix it???
Old Aug 23, 2009 | 11:54 AM
Hammer's Avatar
Its either a bad plug or a break in the wiring to the plug.
Check the contacts inside the plug and see if they look loose and if so use a small screwdriver to gently take some of the slop out of them.This is usually caused by someone wiggling the light out of the socket instead of just carefully pulling the bulb straight out.It will happen with any connector if one wiggles them apart.
Also check the wires going into the plug....
Many times when guys force the bulbs in and pull them out with the wires it will compromise them where they go into the plug itself.When that happens your only recourse is to find a salvage yeard with a wrecked truck and get a new plug or harness.
greenbomb
Chevy/GMC Duramax 04.5-05 LLY
Feb 18, 2018 07:55 PM
carid
Diesel Bombers Sponsors
Apr 15, 2015 07:29 AM
yams
Dec 7, 2014 12:51 PM
