6.0 powerstroke cracked y pipe
Old Aug 22, 2009 | 12:22 AM
aaronmoore's Avatar
Default 6.0 powerstroke cracked y pipe
i was wondering if anyone knew the problems with y pipe cracked.i have truck half way tore apart and i need to get it to the shop cause it aint running right with no power and i was wondering if the cracked y pipe is a major concern.cause if it aint i was gona just go ahead and put back togethor without fixing y pipe.so i can get it to a shop monday cause its my welding truck and i cant make any money with it not running right.thanks
Old Aug 22, 2009 | 10:40 AM
Big Angry Hillbilly's Avatar
It's going to lose turbo drive pressure, and likely be noisy as hell. Which side did it break on?
Old Aug 22, 2009 | 11:26 AM
aaronmoore's Avatar
driver side it is blowin out of the mesh looking stuff on the pipe.pretty good amount the whole firewall and back of motor is full of black sut.and u can see the the blackness around that mesh on pipe.thanks
Old Aug 22, 2009 | 11:29 AM
It definately needs to be fixed, and is not a very fun job to do, FWIW. Best I can offer is take the RH pipe apart, and pull the short section out, then undo the driver's side and wheel the hole business outta there - it's a real ignorant repair to do.
Old Aug 22, 2009 | 11:37 AM
aaronmoore's Avatar
i got it out this morning it was a pain.but can i just cut that part out thats leaking and weld in a piece a pipe
Old Aug 22, 2009 | 07:23 PM
jim_wrench's Avatar
sure can i did that to mine but i welded the top end in place bolted it in place threw the turbo in to get it lined up and tacked it in place then i pulled it back out and tig welded everything....... no more accordian
Old Aug 22, 2009 | 10:49 PM
Accordion FTL, for sure.
Got pics of it all welded up?
Old Aug 23, 2009 | 01:22 AM
aaronmoore's Avatar
ok ill do it that way thanks to all
Old Aug 24, 2009 | 12:05 AM
jim_wrench's Avatar
i can see about getting some pics in the truck but as you are well aware they wont be the best....
plus my welding skillz are not pro
Old Aug 24, 2009 | 07:15 PM
chrispowerstroke09
Oct 10, 2015 12:04 PM
Tylerbuckley
9
Sep 21, 2015 08:24 PM
cjgregory
Mar 31, 2015 01:45 PM
Vince Ruta
Mar 28, 2015 07:20 PM
smbenoit_79
Feb 2, 2015 01:35 PM
