turnin up my 91 cummins
Old Aug 21, 2009 | 10:10 PM
road dog's Avatar
Default turnin up my 91 cummins
I have a 91 dodge cummins and i wanna find a way to turn it up cheap. i don't want a hellah bunch of power. i just want someone to say damn when they see the smoke comin outta my twin 4" stacks. it isn't intercooled and i know this can be an issue with egt's and thats one reason i don't wanna turn it way up
Old Aug 22, 2009 | 11:52 AM
RSWORDS's Avatar
https://www.dieselbombers.com/5-9l-r...g-pump-up.html
I would turn the pin (or even buy a M&H or a DennyT), turn the star wheel down, and remove the high idle screw. Also check to make sure your getting full throttle when the peddle is to the floor.
Old Aug 22, 2009 | 04:56 PM
tower_ofpower's Avatar
X2
there's alot of slop in the factory pedal.. especially after abunch of miles and the plastic bushings get worn. i know mine has to still have some more to it... pedal is sloppy as hell, high idle screw is still installed and the throttle cable gracefully sags on the linkage under the hood... and i still spin tires at 20mph; of course there's no weight on the rear of the truck right now.
Old Aug 23, 2009 | 04:36 PM
road dog's Avatar
there isn't any slop in my pedal or the linkage i've checked that over. where is the star wheel, the high idle screw, and what pin do i needa turn?
Old Aug 23, 2009 | 04:55 PM
https://www.dieselbombers.com/1st-ge...-pump-you.html here is a write-up a member did... it's pretty straight forward and put very simply it's a great write-up... give it a shot and see how you make out...
Old Aug 23, 2009 | 07:21 PM
road dog's Avatar
that post helped me out alot. one thing i wanna knoe is can i just turn the smoke screw to create more smoke or do i needa mess with everything else too?
Old Aug 23, 2009 | 07:26 PM
RSWORDS's Avatar
There is also a Fuel pin give away going on in the contest and giveaway setion right now... I would sign up for your shot at a fuel pin for free!!!
Old Aug 23, 2009 | 08:43 PM
you can do the smoke screw alone; it wont hurt anything; the stock screw limits the adjustment so you cant get too carried away with it. (mines flush with the lock) but; as RSWORDS has said M&H has sponsored and teamed up with DB to do a fuel pin giveaway for first gen guys. M&H makes some good quality pins... i havent heard a bad thing about them. so; make sure your profile and contact information is fully filled out and good luck!
Shun70
Diesel Engine Conversions
Jun 1, 2026 05:02 AM
Dec 18, 2014 03:25 AM
Oct 31, 2014 08:10 AM
Oct 24, 2014 04:40 AM
Omingnome
Oct 20, 2014 12:25 PM
