Lift pump tick or not?
Old Aug 21, 2009 | 09:29 PM
392hemix's Avatar
Default Lift pump tick or not?
I have a tick that comes from my engine. It will come and go, its consistant with RPM But i hear it more @ idel. My truck has no oil leaks, and the Kdp has been adressed. I am almost positive that the noise is either comming from the p7100, or the the lift pump. Just thought i would ask if the lift pump tick common in the 12 valve could be intermitient. I tried putting a pice of wood up to it to listen but the trucks so loud it sounds basically the same everyplace.
Old Aug 21, 2009 | 10:05 PM
biged681985's Avatar
it is very possible the stock lift pump, at least from what all ive been told. good luck gettin it fixed
Old Aug 21, 2009 | 10:42 PM
will1am's Avatar
bio fuel may quiet it down enough to be able to locate the ticking.
Old Aug 21, 2009 | 11:22 PM
captain_stabbin's Avatar
yup, mine does it too, lift pump makes the sound , all it means is the cam lobe is worn nuthin to worry bout mine does it all the time then sumtimes it wont, kinda annoying i know but oh well no big deal
how many miles do you have on ur truck? mine has 300k
Last edited by captain_stabbin; Aug 21, 2009 at 11:22 PM. Reason: Automerged Doublepost
Old Aug 21, 2009 | 11:28 PM
Biggy B's Avatar
yep mines a tickn to but ive got 225k on her sometimes it is annoying but if it aint broke dont fix it!!
Old Aug 22, 2009 | 12:25 AM
12valvetater's Avatar
could be the valve need adjusted i know mine has always had a tick never could figure it out and now that i have an airdog i know for a fact its not coming from the lift pump
Old Aug 22, 2009 | 12:38 AM
Biggy B's Avatar
DO YOU LIKE THE AIR DOG? WHAT IS THE GPM
SORRY I DIDNT READ YOUR SIG
Old Aug 22, 2009 | 08:17 AM
cummins95's Avatar
push in your primer bulb on the lift pump, if it quiets down or goes away, there's ur problem.
Old Aug 23, 2009 | 07:50 PM
392hemix's Avatar
Alright Good deal, next time i hear it tick, i will prime it and see if it goes away. i have just adjusted my valves about 10,000 miles ago
Old Aug 23, 2009 | 08:26 PM
wisconsin redneck's Avatar
yeh mine ticks too.. but i only got 180,000 on the truck.... mine only comes on when i turn the A/C on.. weird
