Can you get injectors Cleaned?
Old Aug 21, 2009 | 09:21 PM
skip59's Avatar
Default Can you get injectors Cleaned?
I have a 2004 6.0 f350 104000 truck was running fine,but changed oil and fuel filters and it started to run really bad so I took it to the shop and they said #1 and #4 cylinders are weak(-30 and -35) it showed on the computer at the shop they had it hooked up to.So is their anything I can do,or can I run something threw it.
Thanks
Old Aug 22, 2009 | 11:19 AM
wildbill's Avatar
Can run some Howes Meaner Power Cleaner through it.
Old Aug 22, 2009 | 11:21 AM
wildbill's Avatar
*wildbill moved
Old Aug 22, 2009 | 01:10 PM
skip59's Avatar
Hey WildBill,Thanks were do I get howes meaner cleaner?
Old Aug 22, 2009 | 06:41 PM
04redstroker's Avatar
Hot Shot's Secret
best stuff ive found. Got two of my injectors workin again, and if it doesnt they refund your money. Its probably stication. Do you keep up with the mant. on this truck. The 6.0s are very picky.
Old Aug 22, 2009 | 10:50 PM
Big Angry Hillbilly's Avatar
^^^^^^^ What he said.
Keep the oil changed - the injection system likes clean oil!
Old Aug 23, 2009 | 09:30 PM
skip59's Avatar
Yes,I change oil around 12,000 to 14,000 and fuel filters about every 20,000 I use rotella 15/40 and lucas oil add. is this ok or should I use or do something different.
Iam sorry thanks and what is that stuff and were can I get it,I hate to have to replace injectors,Its so really weird when I changed oil and fuel filters this all started?
Old Aug 23, 2009 | 09:40 PM
Thats a pretty long interval inbetween oil changes. I never go more 5000. The 6.0 isnt like the old diesel, there very picky with their oil. You also might wanna try running a lighter oil, 10/40. I run 15/40 mystic JT-8 without problems but some people say to run lighter, especially in colder climates. Just click on the link and itll take you to theire site.
Old Aug 23, 2009 | 09:46 PM
skip59's Avatar
Thanks Red Stroker,Do you think what you said early might help me about that stication
Old Aug 23, 2009 | 09:53 PM
I would try the hot shot. If doesnt work, they refund your money, so why not. Its worth a shot to try and keep from replacing inj.
