What's wrong with my truck?
Old Aug 21, 2009 | 12:00 PM
Bad93Cummins's Avatar
Default What's wrong with my truck?
I've noticed that after shutting my truck off for the night, then starting her up in the morning that she's starting to lug starting up for a couple seconds then goes to running/idling like normal and she'll be good for the rest of the day. Anyone know what might be wrong?
Thanks
Old Aug 21, 2009 | 12:42 PM
biged681985's Avatar
have u checked ur fuel filters?
Old Aug 21, 2009 | 01:03 PM
I replaced it about 2 months ago.
Old Aug 21, 2009 | 02:54 PM
RSWORDS's Avatar
All it takes is one bad batch of fuel to ruin a filter. Its pretty common.
I would look for air leaks. There are short hoses from the sending unit to the hard lines on the frame rail that are famous for drying out and cracking. Afer the first start does it start pretty easy after that? If so I bet a small amount of air is leaking in over night.
Old Aug 21, 2009 | 07:41 PM
Ya its only after it sits all night and then the rest of the day its fine. And it just for a very few second when first started up, probley 3-4 seconds just enough to notice.
Old Aug 21, 2009 | 11:23 PM
Rocky Mountain Texan's Avatar
jus prolly have to let it warm up
Old Aug 22, 2009 | 09:55 AM
well it just started 3-4 days ago.
Old Aug 22, 2009 | 11:45 AM
RSWORDS's Avatar
Sounds like there is a leak and air is getting in. Check everything over really good and look for fuel leaks or bad hoses. And just because fuel is not getting out does not mean air cant get in.
Old Aug 22, 2009 | 04:45 PM
tower_ofpower's Avatar
X2
the lift pump design is ok... but not the greatest. the lift pump has a constant draw on the lines from the pump back (which is why air gets in but no fuel out) if you ever notice when guys go from the fatory lift pump to an electric unit; it is mounted as close to the tank as they can get it. just less chance for stuff like this to happen
Old Aug 22, 2009 | 10:44 PM
Well I have tuesday off and once I get some body work and everthing done ill check out the fuel lines.
