Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
2004 ford powerstroke 6.0 p2262
Old Aug 21, 2009 | 01:28 AM
aaronmoore's Avatar
Default 2004 ford powerstroke 6.0 p2262
hello to all my 6.0 powerstroke has no power unless you hold throttle to 3000 rpms for a min then all of a sudden it will run great any ideas thanks in advance already cleaned egr valve replaced map sensor and hose and cleaned turbo
Old Aug 21, 2009 | 03:04 PM
kslb7's Avatar
If your truck is equipped with a Catalytic converter a clog could be causing this too.
Old Aug 21, 2009 | 05:49 PM
aaronmoore's Avatar
it had one but we gutted it and put it back on. also i was messing with it earlier and i found a exhaust leak in y pipe. any thoughts
Old Aug 21, 2009 | 06:28 PM
mysterync's Avatar
Have you checked the vanes in the turbo for free movement? What's the ICP showing?
That exhaust leak will hurt you but would present it's self in low boost, low power all accross the power band!
Old Aug 21, 2009 | 08:41 PM
aaronmoore's Avatar
how do i check the icp yes i cleaned turbo and it was moving freely. thanks
Old Aug 21, 2009 | 08:50 PM
Big Angry Hillbilly's Avatar
You need a scan tool capable of displaying/logging live PCM data to view the ICP pressure. Does the MAP sensor work properly?
Are all the charge air cooler tubes and charge air cooler itself all ok?
Has the VGT been learned properly if the truck has the Inferred EBP calibration?
Could also be an EGR issue. Need VIN or build date of your truck to help any further.
Old Aug 21, 2009 | 09:13 PM
aaronmoore's Avatar
when you crink it the truck has low power and pops through exhaust will barely build 3000rpms and will smoke like crazy then all of a sudden after a min it will go to what it seems like is runnin good but it has a hissy sound but if you kill it back to same stuff.and sometimes it wont open up at all ive noticed turning key on and off several times makes it open up quicker but idle fine and you get exhaust smell in cab but i think thats the y pipe leaking
Last edited by aaronmoore; Aug 21, 2009 at 09:29 PM. Reason: Automerged Doublepost
Old Aug 21, 2009 | 09:31 PM
Air filter plugged solid?
PM me the vin or the build date and I can get you some diagnostic direction.
Old Aug 21, 2009 | 09:35 PM
aaronmoore's Avatar
the shop didnt have a clue they told me they would try and research it but still hadnt heard anything yet
10th month of 2003 thanks
Last edited by aaronmoore; Aug 21, 2009 at 09:35 PM. Reason: Automerged Doublepost
Old Aug 21, 2009 | 09:47 PM
You need to take the truck to a different shop. An 'educated guess' on a Powerstroke driveability concern can cost you upwards of $500 an attempt.
You need to find a good Powerstroke technician. You may have to lay out a little more money initially - but in the long run it will pay off.
Have tools, will travel
