Ford Truck and Powerstroke Turbo Diesel Forum Discussion of General Topics related to All Ford Trucks as well as the Diesels in them
Ford Motor Company Certified Senior Master Tech and Powerstroke Engine Specialist
Old Aug 21, 2009 | 01:18 AM
DB Admin's Avatar
Banned
Exclamation Ford Motor Company Certified Senior Master Tech and Powerstroke Engine Specialist
Mike Cleary has offered Diesel Bombers Members Free Tech Support , He owns two businesses and is usually not online fast enough to help everyone out , but he has offered Diesel Bombers his email address he is very willing to help everyone out If you have any Ford Powerstroke questions that you cannot seem to get an answer for email him ..
Mike Cleary is an eight time award winning Ford Motor Company Certified Senior
Master Technician and Powerstroke Engine Specialist. He was a founding board member
of Ford Motor Company’s Professional Technician Society, an organization dedicated to
serving the needs of Ford dealership technicians in the United States and Canada. He has
served on two separate Ford National Technician Advisory Boards, and received national
recognition from Ford Motor Company for his contributions to Ford as a field technician
involved in improving the 6.0L Powerstroke Engine Program. As a member of Ford’s
IDS (Integrated Diagnostics Software) beta team, he provides field feedback to Ford
regarding how IDS performs on Ford’s newest vehicles. He is an ASE Certified Master
Technician in both the Automobile and Heavy Truck categories, as well as being L1 and
L2 Certified. He is also certified by the state of California as an Advanced Emission
Specialist Technician, and has a Bachelor of Science Degree in Industrial Technology
from California State University, Fresno. He has been a member of the Society of
Automotive Engineers since 1980.
He currently owns his own shop, Cleary Automotive, specializing in high tech
driveability and electronics repairs on Ford vehicle systems. An internationally
recognized trainer, he presents high tech driveability and electronics training for
technicians worldwide for his training company, Automotive Technical Support Services,
in addition to writing automotive diagnostics articles for industry trade magazines. He
has 32 years of continuous experience as a hands-on automobile technician in
independent shops (20 years) and dealerships (12 years).
Attached is the Latest class he is offering if you wish to attend
File Type: pdf
Old Aug 21, 2009 | 01:44 AM
aaronmoore's Avatar
Default 2004 ford 6.0
my truck has no power unless you hold throttle to 3000 rpms then it was throwing a p2262 code now its not already cleaned turbo and egr valve replaced map sensor and hose.any ideas thanks in advance
Old Aug 25, 2009 | 11:44 AM
Mike Cleary's Avatar
What is the VIN?
What else have you tested? Injection Control Pressure, Fuel pressure, etc?
Old Oct 11, 2009 | 05:10 AM
Cubevan's Avatar
I purchased a 99 ford cubevan last year and went on a long road trip signed up with CAA first. Everything was good for a while then( first diesel) 1-)I notice that there was no turbo whistling when I floored it to pass. 2-) when I would get to around a 110 km/ph it felt as if the engine/tranny was off or a neutral feeling and looking in the rear view there would be a big plume of smoke I would let of until the speed was just under 100Km/ then return to about a 100Km/ I calculated that I was getting about 18mpg. my questions are 1-)would the van run if the turbocharger was dead? if so 2-) can someone point out what the reason for the smoke at the higher speed?// I'm leaning that the turbo is shot I see that they are very expensive, I got a line on a used 95 3-)would it fit? 4-) are they hard to RnR
Old Oct 11, 2009 | 05:17 PM
1--van would run but have very low power, especially right out of the gate; 2--what color is the smoke?; 3--It will not fit, and no they are not difficult to change. I'm not certain the turbo is your problem and don't have enough info to even point you in the right direction.
Old Oct 11, 2009 | 08:41 PM
Hummin Cummins's Avatar
Mike Cleary, I must say very nice of you to help Ford owners with your technical expertise!
Old Oct 11, 2009 | 09:12 PM
Cubevan's Avatar
With respect to power it doesn't set you back in the seat but for the size it seems not too bad. But on startup there's is absolutely no power what so ever, I must wait about a half hour before I can even place it in gear.
The smoke seem to be similar to a gas engine with blown oil rings but like I said it's very thick and simultaneously a neutral type loss of power and extreme greyish smoke until the vehicle slows to under 100kph then I can step on it again but once I get to around 110kph the event is going again but going uphill MT I've got to drop to second
what is the aprox. price for a replacement turbo? and how long in shop time to RnR it? the vehicle is sitting in Niagara Falls Ont. and I'm in Regina Sask. I would like to get it here so that I can go to work with it. I'm getting poorer as time lapses without work so I'm trying to get ready to get this repair ready for when I can go there in late Nov.
I would also like to thank you Mike for your help with my problem this take a lot of stress of the unknown from mindplay
Old Oct 12, 2009 | 09:46 AM
It sounds like the EBP butterfly may be sticking. I need more info. Do you have any fault codes?
Old Nov 3, 2009 | 02:00 PM
recycleman's Avatar
Hi Mike,
I have a 2008 6.4 450 and I was wondering about the "cleaning exhaust" feature on the truck. If the truck is used all day long, what would be an acceptable amount of time the exhaust cleaning should be running during one cycle and how many cycles during the day as well?
Thanks for your input Mike.
Old Apr 24, 2010 | 07:51 PM
fords ar us's Avatar
Default fords
hay i have a 2002 7.3l and i can only get 15 18 lbs of boost what should i do
