Broken NV4500 5th gear
Old Aug 20, 2009 | 09:17 PM
Jet A Fuel's Avatar
Default Broken NV4500 5th gear
A year ago I spun the splined drive 5th gear on the outputshaft of my 99 dodge 3500 NV4500 manual trans, hell i wasn't eaven pulling anything it made a loud pop hahahaa. First through Fourth gear still worked that was good (limped home). Installed a new oem output shaft and splined drive gear with a new Dodge tech bulletin retaining nut. Probably not new news to most of you but when it happened to me It was hard to find information on this transmission issue.a year or so latter after doing this Tech bulletin everything is still going good.
Old Aug 21, 2009 | 01:35 AM
coyropin's Avatar
yeah mine poped off once which was coved, but im waiting the day it does it again
Old Dec 4, 2009 | 07:10 PM
USAFGopherMike's Avatar
Just had mine fixed too. Happened at 122k miles.
Old Dec 5, 2009 | 08:37 PM
Sawman's Avatar
happen to most of them sooner or later when i put them on now i always spot weld the net to the shaft if you are neet you can die grind weld off if you ever need inside tranny
99&91cummins
Feb 28, 2015 09:28 AM
rtbcoop
Nov 29, 2014 11:33 PM
GreenDieselF
Nov 9, 2014 07:18 PM
miked2805
Oct 29, 2014 06:20 PM
offroad00
Oct 21, 2014 01:48 PM
