Dodge 3500 brakes shutter rear wheel hop
Old Aug 20, 2009 | 04:53 PM
Jet A Fuel's Avatar
Default Dodge 3500 brakes shutter rear wheel hop
Is there any 3500 dodge owners that experiance rear wheel shuttering or hopping when normally braking. Is there a known speed sensor problem?
Old Aug 20, 2009 | 05:10 PM
bryson's Avatar
Speed sensor would have nothing to do with a shudder or hop... Sounds like you have contaminated brake shoes (from a leaky wheel cylinder or wheel seal) or possibly some broken parts in the drum...
Its worth pulling the rear drums to have a look.
Old Aug 20, 2009 | 05:19 PM
Jet A Fuel's Avatar
It feels like an anti lock brake pulseing. There is a speed sensor in the brake system thats how it references when the tire starts to skid. Changed shoes to try to fix the problem even turned drums no broken parts.
Old Aug 22, 2009 | 02:27 AM
bryson's Avatar
I guess it could be an ABS issue... The sensor is on the top of the rear differential, and I believe it is held in with one bolt. Maybe there are teeth broken off of the ABS ring in the diff? Anyways, pull out the sensor and peek through the hole with a light and see if there are broken teeth. Probably want to put the rear axle on jack stands/trans in neutral/park brake off so you can spin the d-shaft and watch the ring turn.
Old Aug 22, 2009 | 08:40 AM
Buckshotmckee's Avatar
Sma't Alec!
My guess would be a bad master cylinder, proportioning valve is bad.
Old Nov 6, 2009 | 08:41 PM
sledwrecker's Avatar
I'm not sure but don't they have a brake proportioning valve above the axle that is hooked to a linkage that senses when you have a load on the truck (suspension compressed) That limits brake power to the rear axle when unloaded? If it was at fault and was giving 100% brake power to the rear axle when empty I think it would act like what you are experiencing?
Old Nov 6, 2009 | 09:06 PM
dirt diggler's Avatar
i had the same prob whith my 01 but the break light on dash was on. By luck i unpluged the wire above the rear end and my abs light stays on but no wheel hop and stops fine ill fix the prob latter. But it only takes a second to unhook the plug an see what you have . Mine has been runnin for a month like this whith no prob.
ILLUSHA
Diesel Engine Conversions
10
Aug 21, 2015 05:48 AM
Jet A Fuel
For Sale
Aug 16, 2015 04:44 AM
jrock0805
Jul 28, 2015 02:03 PM
kerley
Wanted To Buy (WTB) - Used
Jul 12, 2015 11:00 PM
jstoshick
For Sale
Oct 2, 2014 10:24 PM
